Old 10-05-2020, 02:31 AM   #1
BeaverMeat
BeaverMeat's Avatar
Default headlights and Fog lights!
Looking to upgrade the exterior lighting on my ‘81. It sucks.
Headlight:
Looking for suggestions and experiences with upgraded 4x6 low beams. On my search I have only been able to find the chintzy aftermarket “projector” and LED lights. Been looking at the Hella Vision Plus or the Phillips LED.
Fog lights:
Wanting to go with a factory style Bosch set-up. I have seen some original kits but, they are a bit pricy... and I want yellow lenses. ;)
I’m also wanting to get a rear fog light. It’s looking like I may need it on the island.
Does anyone have any experience wiring up a factory style fog lights with OE switches?
Thanks!
Old 10-05-2020, 03:20 AM   #2
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Unless you must have LED headlamps, go with a set of H4/H1 E-code headlamps. If you truly want LED, I'd look at the JW Speaker 4x6 LED modules. They have an E-code beam pattern and don't look strange in a 1980s car. They aren't cheap, though.
For rear fog lamps, if you have a GLT, GLE, 262C, or Turbo, easiest way to do it, is to add the wiring from a 1985 car to the dash harness, then swap out the driver's taillamp circuit board and the passenger taillamp with parts from a 1985-93 car. If you have a 245, then just add the extra terminal strips and move the brake light wires to the lower red lens, while plugging in the white fog lamp wires into the top red lens terminals. On a 5-panel taillamp car, you might need to use a separate rear fog lamp mounted to the bumper or to the tail panel next to the license plate.
1982 242Ti - black, M46. 1985 245Ti - blue, M46 - soon to be for sale.
@john242ti on IG
Old 10-06-2020, 05:01 PM   #3
mikep
The MP
mikep's Avatar
Peterson makes an inexpensive ($35?) LED rear fog. 2.5" x 4" ish, and very bright. It says to mount vert, but works great horiz.
Old 10-06-2020, 06:02 PM   #4
LC4CARL
Aero challenged
LC4CARL's Avatar
I prefer a "driving" pattern over a "fog" pattern.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 10-07-2020, 12:23 AM   #5
Toybox
mostly lurking
Toybox's Avatar
It would be difficult to find anyone more knowledgeable than Dan Stern. Lighting, bulb choices, mfr histories, regulations all over the world... and Volvos, to boot. http://www.danielsternlighting.com/
That's useful if it's really, truly foggy. But I've followed many a person who apparently turns on every possible switch before driving, even in clear weather. Damn, that's annoying.
Old 10-07-2020, 12:40 AM   #6
James M
Bored member
James M's Avatar
We just put hella 4x6 H4 conversion bulbs in my GFs 245, made driving at night much better. IPD sells them for ~$150 for a set of outer bulbs.
LED is gross don't do it
Old 10-07-2020, 09:40 AM   #7
mikep
The MP
mikep's Avatar
Same. I replaced my 03 wrx fogs with Hella 500s from rallylights.com
Old 10-07-2020, 12:03 PM   #8
245gti
Adapting Stuff
245gti's Avatar
I just did a major tidying of my garage and found a tub full of 4 x 6 H4/H1 sets I've pulled from junkyard cars over the years. I'm pretty certain we can put together a matching set for you. I've also got some 80/100W H4 bulbs and some yellow 100W H1 bulbs. All would need to be wired through relays to gain the full benefit of the higher power bulbs. PM me and we can discuss price. I'm in Calgary and it looks like Canada Post is offering free shipping Tuesdays for a few weeks...
Dale
Old 10-07-2020, 01:56 PM   #9
VolvoGLT
VolvoGLT's Avatar
Here is my setup. Let's put it this way, I have no problem seeing the roads at night.
VolvoGLT is offline   Reply With Quote
Old 10-09-2020, 03:51 AM   #10
John242Ti
John242Ti's Avatar
^Same setup on my wagon.
Old 10-10-2020, 03:19 PM   #11
BeaverMeat
BeaverMeat's Avatar
My car is a six panel. 1981
Old 10-10-2020, 03:21 PM   #12
BeaverMeat
BeaverMeat's Avatar
Fortunately for me my car has the quads so I won't need the extra lights.
Old 10-10-2020, 06:05 PM   #13
mikep
The MP
mikep's Avatar
Yeah, but once you see what a good set of driving lights will do, you’ll always have a set.
Old 10-10-2020, 06:57 PM   #14
Fa182
Stage 1
Fa182's Avatar
Unfortunately for me my car has the quads so I need E-Codes
FTFY
Old 10-10-2020, 07:26 PM   #15
BeaverMeat
BeaverMeat's Avatar
Can only find low/high and high e-codes. No lows
Old 10-10-2020, 07:54 PM   #16
245gti
Adapting Stuff
245gti's Avatar
Not sure what you're saying. The H4/H1 setups are Low/Hi H4 and Hi H1. Are you looking for something that doesn't exist?
Old 10-10-2020, 09:10 PM   #17
Centsableone
SNAFU - BOHICA
Centsableone's Avatar
Chicks dig a "driving" pattern over a "fog" pattern.
Originally Posted by cleanflametrap View Post
Take care with your mods. In the past 20 years I've read a story or two about monkeyed seat heaters being the cause of a serious carbecue.
1983 245T, 1986 244, 1990 745T, 1990 245, 1982 4- speed 245D,
Currently: 1990 245 and 1992 244
Sale and Purchase Feedback
Centsableone is offline   Reply With Quote
Old 10-10-2020, 10:39 PM   #18
BeaverMeat
BeaverMeat's Avatar
Yeah... I just figured that out. Dirp!
Old 10-11-2020, 06:40 PM   #19
Good for the money yellow fog lights are Hella 550 in amber. Also if you want to spend more and get a higher quality product. Cibie makes really nice amber fog lights.
