Old 05-12-2021, 06:33 PM   #1
mschultz373
mschultz373's Avatar
Default drove thru water, car died
mild street flooding is a common thing here in SE louisiana, so the other day during a storm, I drove through 2-3in of water on the street - probably around 10-15mph. fast enough that it splashed in an arc away from my tires... but apparently also into the engine compartment. immediately afterward, the car stalled out and died and wouldn't start again. i left it until later that day, several hours after the rain and when the sun had come out, and the car started and drove normally.
so i'm assuming something splashed on a connection that disabled the ignition or fuel delivery? i didn't have all my tools on me so I couldn't do too much diag, but i know that while cranking the car during the condition, the ignition coil was firing.
i know it's kind of a tough thread without further diag (and i'm not sure how badly i want to go drive thru more water next storm just to figure this out...) but i am curious if anyone else has had this kind of problem before, and if so, knows what it is?
thanks.
mschultz373 is offline   Reply With Quote
Old 05-12-2021, 11:51 PM   #2
VolvoScout
VolvoScout's Avatar
I've had similar problems with 240s and rain in the past, although I never quite figured out the exact reason...
In your case, a cheap belly pan under the engine would help keep water from entering under the car and causing havoc in the bay.
Old 05-13-2021, 01:38 AM   #3
Khrrck
Professional Amateur
Had that happen to me. Old timer nearby suggested I check inside distributor cap for water. Sure enough it was damp and drying it out stopped the spark from shorting.
'87 240 budget wagon.
Old 05-13-2021, 04:44 AM   #4
OttoB
Fuel pump connectors?
Old 05-13-2021, 11:03 AM   #5
Mr. V
Mr. V's Avatar
Almost certainly water in the distributor cap: a common problem in flood conditions.
Old 05-13-2021, 12:28 PM   #6
go240go
Would this still be the case even with a belly pan in place? I've had the stalling issue recently, when driving into a drive-thru car wash during the underbody spray phase. It started right back up though luckily. I'm thinking it had to do with some wiring that runs under the engine that probably shed its insulation (it's an '87).
go240go is offline   Reply With Quote
Old 05-13-2021, 12:28 PM   #7
kyote
Living The Dream
kyote's Avatar
What happens is as soon as water gets in the fan it blows it straight back at the dizzy cap.
Put a can of WD40 in your trunk, and if it happens again, hose the inside of the cap and rotor with WD40 and then you will be back in business.
kyote is online now   Reply With Quote
Old 05-13-2021, 01:24 PM   #8
Dan
Watching the World burn
Dan's Avatar
Later 240s have a fuse on the firewall thats known for problems if the cover gets cracked etc. Most likely dist, but if newer than 86 I think, check that fuse on the firewall on drivers side
1985 Chevy TPI V8 740.
Dan is online now   Reply With Quote
Old 05-13-2021, 02:50 PM   #9
Khrrck
and they tend to get corroded or melt - I replaced mine with a rubberized, waterproof fuse holder from the local autoparts store.
Old 05-13-2021, 04:34 PM   #10
Bready
board deviant
Bready's Avatar
^This
Originally Posted by Pennybridge Pioneer View Post
Just because you didn't experience something growing up doesn't mean other people didn't. Case in point: I can't remember ever being a total moron, but that doesn't mean you aren't one.
A society that treats this much Black death at the hands of the state as collateral damage in a just war on crime has no decorum to project. That society is savage. - Charles M. Blow
Kalazdar - (3/23/83 to 5/12/03)
MUST READ!!! https://cleantechnica.com/2017/04/24...-adds-screwed/
Bready is offline   Reply With Quote
Old 05-14-2021, 08:30 PM   #11
Johnnya101
Had the same problem on my 91. It would die or be very hard to start and would stall in heavy rain.
Microcracked distributor crack that was over 100k miles old.
Cheap and easy fix. You should replace the wires while you're at it. And the rotor.
Start the car, let it idle. Grab a spray bottle of water, and spray the distributor with a bit of water, until it's running off the top. It should not have any effect on rpms. If it stalls and bucks, you know it's bad.
HAVE
1991 245SE here
SOLD
1988 240DL Sedan
Johnnya101 is offline   Reply With Quote
Old 05-15-2021, 01:05 AM   #12
mschultz373
wow, that sounds like right on the money. i'll have to try this.
Old 05-16-2021, 04:32 PM   #13
90volvo
mine would do that, was a busted coil.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
