Old 05-18-2021, 06:04 AM   #1
VolvoLatAm
VolvoLatAm's Avatar
Default Has anybody gotten a hot interior after installing the tropical clutch fan?
Has anybody gotten a hot interior after installing the tropical fan clutch?
I installed a tropical clutch fan that blows hard/keep radiator cool (also kills gas mileage).
Now all of the hot air is somehow directed at the transmission tunnel (which volvo never put heat shielding on) and it makes the interior pretty much an oven like the interior in a viper or miata.
I have a nissen's radiator and I am just going to get an electronic fan that doesn't push so much heat into the cockpit because I can't deal with this
Old 05-18-2021, 11:23 AM   #2
Khrrck
Professional Amateur
Are you sure your heater valve hasn't failed in the ON position like they tend to do?
'87 240 budget wagon.
Old 05-18-2021, 11:31 AM   #3
JohnMc
JohnMc's Avatar
/\ /\ /\ What he said. Failed on mine, I put up with it for a while until the middle of the LS swap when I had that firewall heater connector out anyway. Little plastic valve ball just came loose from the lever, and stayed open regardless of the lever position.
Try pinching one of the heater hoses shut in the engine bay and see if that improves the situation.
The engine produces a certain amount of heat, I don't think blowing less air through the radiator will really help the situation. Where else will it go?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 05-18-2021, 02:34 PM   #4
VolvoLatAm
VolvoLatAm's Avatar
Guys I already have the heater valve blocked off mod
Old 05-18-2021, 04:36 PM   #5
James M
Bored member
James M's Avatar
Come on guys you haven't read his entire post history before commenting?
Old 05-18-2021, 04:37 PM   #6
Khrrck
Double check to make sure it's working.
The heat from your engine goes only four places: the radiator, the heater core, the exhaust, and radiation from the block itself into the engine bay.
Even with a normal fan clutch the inside of the bay gets super hot. I really don't think the slightly increased airflow from the tropical clutch is making the flow through the transmission tunnel significantly hotter.
Old 05-18-2021, 07:06 PM   #7
If you install the seal around the shifter. That may help some. It is normal for the shifter to get hot in the heat of the summer around here.
Old 05-18-2021, 10:12 PM   #8
90volvo
they make a foam piece that goes under shifter boot. I just used a push mower foam air filter, worked great cut down on heat and noise.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 05-18-2021, 10:56 PM   #9
VolvoLatAm
VolvoLatAm's Avatar
when it is blocked off, it means there are no hoses connected to the wall. it circulates the jacket water in a loop! Disconnected/looped I guess!
Old 05-18-2021, 11:05 PM   #10
VolvoLatAm
VolvoLatAm's Avatar
there is no need for your comments, I don't need to mention anything about my heater valve. Everybody on these car forums dangerously assumes things.
On the porsche forums if you ask where to buy certain parts they always tell you how to fix you car vs telling you were to buy 'x' part. It's the same everywhere I guess.
If you're going to suggest something that I didn't mention for the cooling in the car, you might as well ask if I was shirtless or wearing a ski jacket in the same manner.
Old 05-18-2021, 11:07 PM   #11
VolvoLatAm
VolvoLatAm's Avatar
Just found some of these on the internet, they look good. I should have heat shielded everything when the transmission was out for good measure--this is the go-to miata mod.
Old 05-19-2021, 11:42 AM   #12
Using generic foam is not a good idea for a shifter seal. The foam that Volvo uses doesn't absorb water. The generic foam absorbs water and will keep wet foam up against the body of the car. Maybe if you coated the foam with something to stop the water being held in the foam.
Old 05-19-2021, 11:53 AM   #13
apachechef
Burnt Sierra Madre
did you whine about it on the porsche site too?
Dammit, Lummert.
Old 05-19-2021, 12:01 PM   #14
JohnMc
JohnMc's Avatar
So if the fan blows less air through the radiator, where does the heat generated by the motor go?
Do you have any obvious air leaks where air in the engine compartment could blow into the interior?
Old 05-19-2021, 04:07 PM   #15
gold foil all the things
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-19-2021, 06:12 PM   #16
apachechef
Burnt Sierra Madre
there is no need for your comments, I don't need to mention anything about my air leaks. Everybody on these car forums dangerously assumes things.
Old 05-19-2021, 11:08 PM   #17
VolvoScout
VolvoScout's Avatar
I'm in the Northeast, so it may not be as noticeable as down South, but I have not noticed any increase in cabin temperature or measurable change in fuel economy since installing the tropical fan clutch in a B230F and D24.
Old 05-20-2021, 12:07 PM   #18
90volvo
I remember now, this might be redneck but I wrapped it with heavy duty duct tape. lol.
Old 05-22-2021, 04:14 PM   #19
RickATL
Family's fleet manager
RickATL's Avatar
Default I assume you have checked the.....
I only put the tropical fan clutch in my 240's .......never had the problem you are describing.
Feedback thread: https://forums.turbobricks.com/showthread.php?t=353892
91 245 re-christened “The Mistress” 012021
93 244 "Lars"
92 245 "Astrid"
Past
88 245 "Margit" sold
93 244 completely disassembled - It died, so many of its parts could help others live.
97 855 T5
97 855 NA
RickATL is offline   Reply With Quote
