Old 05-18-2021, 01:10 PM   #1
Benjam83
Moar Volvos than Queen B
Default '93 240: Water leaking from the top of the A-pillar (no sunroof)
Ok, so the title pretty much sums it up. I've got a non-sunroof car. We're in the middle a week of solid rain, and I'm DDing it right now. I've got water leaking into the cabin, at the top of the A-pillar interior panel, running down the A-pillar. I'm pretty much assuming that my windshield is leaking....so that's one thing. It's still got the original windshield, amazingly. And I'd like to keep it that way. What is the general consensus on re-sealing the windshield....the right way? I swung by the local auto-glass place and they recommended a body shop take a look at it. But I wanted to consult the brain-trust here. There's no visible rust around the windshield.
I've found thing one that just talks about the different windshields and molding...which is fairly useful.
https://forums.tbforums.com/showthread.php?p=5231132
And then, here's the molding that can be had here. The roll butyl stuff that's supposed to seal the glass to the frame can be had separately...
https://www.volvopartswebstore.com/p...0/3540053.html
Google searches yielded some results from "water leaking into the cabin"...from people with sunroofs....will a non-sunroof car still have the drains that need to get un-clogged?
Am I missing anything?
Thanks in advance...
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 05-18-2021, 01:18 PM   #2
Homer
OEMplus++
Homer's Avatar
Ben, I had the same issue on my 90 with the original windshield. You COULD replace the sealant, that was the issue with mine. I ended up just ordering a new windshield from volvo and having it replaced.
-Jacob:
2017 allroad - Comfy DD
Old 05-18-2021, 04:40 PM   #3
Khrrck
Professional Amateur
I have the same issue and it's definitely a leaky windshield.
'87 240 budget wagon.
Old 05-18-2021, 06:57 PM   #4
That is the spot that was leaking on my 93 windshield before I had the glass replaced. Your windshield being original was installed with the butyl tape which is good for a diy person. You can use a piece of cable like a brake cable from a bike and cut the old windshield out with it. Make two loop handles and wear gloves so you can pull pretty hard. A nice warm day will soften that stuff up. Don't lose the small rubber spacer blocks that you place at the bottom of t he windshield. Take your time and it's best to have a helper work the glass with you. Be gentle it's very easy to crack the glass and then your into a new windshield.
Old 05-19-2021, 08:56 AM   #5
Benjam83
Thanks guys...Not the answer I wanted, but the answer I needed...
Definitely weighing how important the original windshield is to me...I think it's cool that it's the original...but not having water run into my car is even cooler...
