Old 05-18-2021, 03:32 PM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default M47 mods for better "feel"
I will need a clutch soon and will likely refresh my M47 while its apart. I need a first gear syncro for sure. What else should I do while its apart? Any easy or "have to do" mods while I've got it out of the car?
Use will be sporty daily driver. Just looking for a better feel and easier rev matching. No turbo, just a warmed up NA b230.
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 05-18-2021, 04:42 PM   #2
spock345
spock345's Avatar
The STS shifter bushings are a good idea. Bronze and delrin. Makes the shifter more solid and minimizes the slop. A 164 engine mount as a heavy duty transmission mount also helped with shifter feel on mine.
It might be hard to find that synchro unless you have another gearbox for parts.
1967 122s, B20F, M40
Old 05-18-2021, 04:50 PM   #3
culberro
culberro's Avatar
If you can handle the vibrations, replacing the shifter cage bushings with something other than blown out rubber really helps too.
You can also rebuild (re-pin) the shifter u-joint thing if it has a bunch of slop.
Old 05-18-2021, 04:58 PM   #4
The shifting rod coupler on mine had a lot of play. Replacing that made a world of difference.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
blkaplan is online now   Reply With Quote
Old 05-18-2021, 05:06 PM   #5
culberro
culberro's Avatar
Are you talking about the u-joint part, or the fork that goes around the bottom of the shift lever?
Old 05-18-2021, 05:29 PM   #6
I suppose you could call that the u joint.
its part that has the sheet metal sleeve you have to remove to pull the dowel pins out of.
Old 05-18-2021, 07:17 PM   #7
That coupler cover sleeve is no longer available. So be careful not to ruin it when replacing the oring in the coupler and checking it for play. I second the trans mount upgrade to the 164 mount. That works very well and your shifter won't jump around anymore.
Old 05-18-2021, 08:34 PM   #8
HiSPL
HiSPL's Avatar
Solid.
I grabbed some Diesel motor mounts the other day on facebook. That and the 164 mount will be as stiff as I'd want it I think.
Old 05-18-2021, 08:42 PM   #9
apachechef
Burnt Sierra Madre
replacing worn parts makes it really good again. ymmv, but i found oem shifter parts fit better and felt better than sts stuff
Dammit, Lummert.
Old 05-19-2021, 06:19 AM   #10
jtbechtold
I put the brass bushing from sts in mine feels great! much more precise feel but i mean the best mod would be a cd009
jtbechtold is offline   Reply With Quote
Old 05-19-2021, 09:23 AM   #11
spock345
spock345's Avatar
CD009, T5, Getrag, etc. All would give you easier access to new synchros and other rebuild parts. But I have a feeling that it would be going a bit too deep down the rabbit hole for a mild NA B230.
Old 05-19-2021, 12:56 PM   #12
HiSPL
HiSPL's Avatar
Yes. The whole point of this car is to keep it uncut and use stock stuff.
If I put in a T5, well I might as well drop in the B6304 because I already have the adaptor, etc, etc.....
One of these days I'll find the perfect 242 shell to build the hot rod of my dreams. Until then I'm just gonna commute in this 244.
Old 05-19-2021, 01:56 PM   #13
philski o'flood
philski o'flood's Avatar
see if you can get a Homer short throw shifter, they are nice
philski o'flood is offline   Reply With Quote
Old 05-19-2021, 02:29 PM   #14
HiSPL
HiSPL's Avatar
Word
Old 05-19-2021, 03:01 PM   #15
culberro
culberro's Avatar
Originally Posted by HiSPL View Post
Word
They are nice. Also, don't be afraid to make your own, it is pretty darn easy. Just a short section of 1/2" rod or a bolt and a welder, iirc.
Old 05-19-2021, 03:14 PM   #16
SteveMD
Membro
SteveMD's Avatar
I seem to recall that the case would flex when hit with quite a bit more power than stock and (can't remember which) gears would move apart far enough to start stripping teeth off one (or both).
I wondered if an external steel girdle might provide support to prevent the above happening.
But this probably no concern for HSPL's stockish setup.
2013 XC60 T6
2006 330i
Old 05-19-2021, 03:16 PM   #17
HiSPL
HiSPL's Avatar
Lulz. My 112 furious horses are going to rip that case apart!
Old 05-19-2021, 03:48 PM   #18
2manyturbos
I think hiperfauto will have the syncro.
Old 05-23-2021, 09:11 AM   #19
shoestring
shoestring's Avatar
For what it's worth, I've never missed a shift with the stock setup in almost 10,000 miles of road racing.
Old 05-23-2021, 09:46 AM   #20
HiSPL
HiSPL's Avatar
That's cool.
I set the lap record on the nurburbring with stock 14" steelies and Eco tires.
Old 05-24-2021, 10:17 AM   #21
shoestring
shoestring's Avatar
That's cool.
I didn't realize that was a recognized category. You're going down.
Old 05-24-2021, 01:19 PM   #22
HiSPL
HiSPL's Avatar
Bring it!
