Old 10-21-2021, 08:59 PM   #1
HiSPL
Fanking Champion 1993
HiSPL's Avatar
Default Rear triangle removal question.
If I take the fuel tank bolts out do the rear triangles just slip out of there? Or are they also welded to the chassis?
My car has undercoating on it so i don't want to go scraping that off just to find I need to cut them anyway....
Trying to fit my 2.5" exhaust.
Beets taste like buttfeet.
Originally Posted by Lando
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 10-21-2021, 09:01 PM   #2
Old and boxy but good.
They are clamped between the fuel tank and the body. Just support the tank, remove the bolts and you can slip them out. They save a good chunk of weight. Look out for the hidden third bolt.
Old 10-21-2021, 09:15 PM   #3
HiSPL
HiSPL's Avatar
Sweet. I'll buy you an ebeer.
Old 10-24-2021, 10:57 AM   #4
JohnLane
Then remove the pair of brackets that bolt to rear calipers for additional weight savings.
Old 10-24-2021, 11:48 AM   #5
HiSPL
HiSPL's Avatar
Yeah plan to do that when I go through the brakes later.
Building an exhaust right now. I have stainless brake lines for the future. Will do new pads, rotors, stainless lines all around but thats in the future.
Old 10-24-2021, 06:26 PM   #6
mikep
The MP
mikep's Avatar
I always removed them but i’m on the fence with the latest 245. Keeping the tank away from the axle in a rear-end collision would be sweet. I’m seeing more and more close calls with brodozers recently.
It was a Datsun, it was more likely rust in something ...
Originally Posted by propav8r View Post
Ain't my couch.
F*ck that couch.
