Old 12-21-2021, 10:07 PM   #1
euro-trash97
euro-trash97's Avatar
Default TruTrac Tone Ring
Im trying to put a trutrac in my 240 but I dont have a tone ring, where can I buy one?
Originally Posted by Captain Bondo View Post
If by "can't drive a manual", you mean "refuse to drive like a pussy", then yeah, I can't drive for sh8t.
euro-trash97 is offline   Reply With Quote
Old 12-21-2021, 10:17 PM   #2
The Librarian
https://www.bneshop.com/collections/...d-sensor-strip
Old 12-21-2021, 10:26 PM   #3
euro-trash97
Thanks bro, I was literally just looking on there.
Old 12-22-2021, 12:51 PM   #4
As an FYI, if the TruTrac housing isn't machined down to fit the tone ring you won't be able to install or remove the ring gear.
So you have to weld the tone-ring on with the ring gear already installed.
Or have the case of the TruTrac machined down to fit the strip.
Originally Posted by Toyotahead View Post
That's why you give blowies with a mouth full of Listerine, sanitizes the sausage and leaves everyone with a fresh clean wintergreen taste or scent!
Originally Posted by megulon-7 View Post
Sigh…. It leads to the hard stuff. Hot sauce or I can’t get off now.
Old 12-27-2021, 08:06 PM   #5
mikep
The MP
mikep's Avatar
If it’s the newer (588) case it is very tough to machine.
The older versions are easy to cut in a lathe.
It was a Datsun, it was more likely rust in something ...
Originally Posted by propav8r View Post
Ain't my couch.
F*ck that couch.
Old 01-05-2022, 03:33 PM   #6
DrZiplok
DrZiplok's Avatar
You can also just cut the tone ring teeth into the housing with an angle grinder. There's lots of meat there, and you don't have to be *super* precise for it to work.
DrZiplok is offline   Reply With Quote
Old 01-05-2022, 03:48 PM   #7
I haven't had good results with that.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-05-2022, 08:07 PM   #8
mikep
The MP
mikep's Avatar
Was that yours i did, Ben? I remember doing 2 or 3, i think Steve’s worked ok, anothere had needle bounce.
Definitely not my favorite method.
Old 01-05-2022, 10:19 PM   #9
apachechef
Burnt Sierra Madre
SteveMD's had needle bounce, It's mine now.
some might have been from the sensor rubbing against the truetrac and wearing through the plastic, into the copper in the sensor
Dammit, Lummert.
Old 01-06-2022, 04:10 PM   #10
mikep
The MP
mikep's Avatar
Yeah, it needs to have more space between metal areas to induce a good signal.
Old 01-06-2022, 05:08 PM   #11
You did towerys and mine, neither worked well at all.
Old 01-06-2022, 05:28 PM   #12
I used the Towery one many moons ago. Can confirm it did not work well.
Old 01-06-2022, 07:39 PM   #13
mikep
The MP
mikep's Avatar
That’s how experiments go sometimes. And we learned from it. I’m actually surprised someone else hosted that pic.
Old 02-04-2022, 12:41 AM   #14
DrZiplok
DrZiplok's Avatar
Worked great for our ABS; possibly the duty cycle is wrong / bad for the 12t speedo?
Old 02-04-2022, 06:23 AM   #15
I think that’s it.
With a 48t wheel (stock) the teeth width and gap width is almost exactly the same (maybe it is the same?)
12t is waaaayyyy different.
Old 02-04-2022, 12:29 PM   #16
I think that’s it.
I could see that.
Old 02-04-2022, 12:38 PM   #17
badvlvo
Bad for Babies
badvlvo's Avatar
Welded teeth on my last one, worked fine. Guy who bought it wanted them ground off before he would buy it. LOL.
RIP BADVLVO 3/1/1980-10/10/2015
Died at age 35
1988 244
badvlvo is offline   Reply With Quote
