Old 01-08-2022, 12:38 PM   #1
rb92673
Default Budget racing options for diff
At our last race at Sonoma we were getting a lot of wheel spin on right handers such as turns 2, 4, 7 & 11. At Buttonwillow wheel spin is most noticeable at turns 2 and 10. Suspension has recently been upgraded to BNE coilovers with Koni race single adjustables, but we had the problem before upgrade. Car is a '85 745t at about 200 rwhp. I have never opened the diff, but I am pretty sure it's just an open diff.
A Gripper is not in the budget for a while, so I am looking for options and experiences for endurance racing. As far as budget options I think my options are:
- Suspension tweaks and deal with it
- Weld it, deal with the under steer
- G80 with weight cut
We plan on racing four times in 2022. Willow Springs, Thunderhill, Buttonwillow and Sonoma.
Old 01-08-2022, 01:04 PM   #2
mikep
The MP
mikep's Avatar
Lunchbox locker.
It was a Datsun, it was more likely rust in something ...
Originally Posted by propav8r View Post
Ain't my couch.
F*ck that couch.
Old 01-08-2022, 01:05 PM   #3
Old and boxy but good.
Here is another option one of our Euro members posted.
https://forums.turbobricks.com/showt...ghlight=lsd%2A
I bought one to try but haven't installed it yet.
Old 01-08-2022, 01:09 PM   #4
The best extreme budget bet for a lemons car is a g80 with the weight welded in place. That shaft can break if you cut the weight so its better just to reinforce it.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 01-08-2022, 01:50 PM   #5
rb92673
Lunchbox locker.
Have you used one on a track? Was it locking and unlocking in corners?
Has anyone actually used one yet on the track?
Noted, thanks.
Old 01-08-2022, 02:13 PM   #6
gsellstr
Vintage anti-ricer
gsellstr's Avatar
There's some lockers on FB right now, might take a peek at the Dana 30 stuff. The Spartan's have a decent rep for quality, can't comment on performance on the track though.
RIP
Nick Fengler "fengler" 8/6/18
Bob Davi "bob davi" 10/2021
74 144 B20
90 745Ti
Old 01-08-2022, 03:02 PM   #7
I've had really poor experiences with g80 lockers with on track use. Mine was a low mileage unit with the weight welded down. It was ok for the first track day, but started to lock after ~1 sec of wheels spin and then stay locked. 2nd track day it was very unpredictable unless driven with absolutely no wheel spin (and then what's even the point of the diff?). It had a habit of engaging inconsistently, which meant for a lot of high speed drifting in corners where you would be full throttle.
Lunchbox locker would be what I'd do now (as MikeP mentioned), or a used detroit locker center section (or similar). Extremely predictable. Throttle on = locked, throttle off = open. You can't on-off-on the throttle in corners without it being a bit odd, but you learn quickly how to drive with them. Once again, they are very predictable and you will feel what the tires are doing.
They are easier on axles than a welded diff, and you get great turn-in with a locker.. but once on power it handles like a locked rear end.
Trans-Am and road course NASCARs used them for decades (and maybe still do).
Originally Posted by Toyotahead View Post
That's why you give blowies with a mouth full of Listerine, sanitizes the sausage and leaves everyone with a fresh clean wintergreen taste or scent!
Originally Posted by megulon-7 View Post
Sigh…. It leads to the hard stuff. Hot sauce or I can’t get off now.
Old 01-08-2022, 03:12 PM   #8
msweeney
msweeney's Avatar
I know at least a few of the TA2 front runners are using Wavetracs. NASCAR is going to a transaxle, so real diffs.
I spend a lot of time around race cars. A lot.
1975 245: Pea green, kinda rough. B234 swap (rebuilt, balance shafts deleted, H-beam rods), Hy35, KLRacing header, external TIAL gate, NPR, shortened stock intake manifold, Link G4+ Monsoon ECU, T5 WC, front coilovers on raised strut towers, and a never-ending, ever-expanding list of dumb ideas
8v B230F w/ HX35, dual plenum manifold, full Megasquirt 3 ECU and harness w/ all sensors, just looking for a shell to put it in.
msweeney is offline   Reply With Quote
Old 01-08-2022, 03:33 PM   #9
Yes, there are better options out there. But the locker is at least a proven to work well in higher level motorsports applications. I know that trans-am (and cup cars) were limited by rules on what diffs could be used, but they made spool and locker cars work very well.
And you can still run a locker in a transaxle
Old 01-08-2022, 04:00 PM   #10
msweeney
msweeney's Avatar
I should have clarified, I love me a locker! Just kind of absent mindedly scrolling and volunteering info, it kinda came out wierd. The Wavetrac ain't all that special, but it seems to be sneaking in wherever people used to employ lockers.
The Next Gen uses that fancy gas-charged positive preload diff that's been in IndyCars for a while. I assume they'll have a spool for ovals, though, so it ain't too fancy for a locker if they make one that fits!
Old 01-08-2022, 04:05 PM   #11
rb92673
Thanks for that feedback. I know several racers that are disappointed in the TruTracks/Wavetracks. Interesting experiences with the G80s.
Forgive my ignorance, but a Spartan locker for a Dana 30, 27 spline is what I should be looking at assuming I have an open diff?
Old 01-08-2022, 05:34 PM   #12
A TruTrac is crushingly disappointing when they lift a wheel. I've driven fast fwd cars that were set up stiff in roll and they would inside wheelspin on the track, especially if you got on the curbing.
And yes, D30, 27-spline locker. I've had great luck with the Spartan brand.
FYI: You will need to pull the carrier and ring gear (and cut off the oil slinger if you have it on), to remove the center pin on the diff. Unless you have a really good slide hammer setup that will grab the inside of a roll-pin.
Old 01-08-2022, 05:37 PM   #13
No worries. I love the higher end road racing experience you bring into posts
I'm curious how the new cup cars will do on the ovals. The changes should make them much better on a road course, and I'm really hoping for some V8 supercars type of action!
Old 01-08-2022, 06:00 PM   #14
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Something like a lunchbox seems like it would be a huge upgrade over a welded diff or G80 both in terms of durability and handling.
No experience with it, though. I hated my G80 with a passion.
I sell chips for LH 2.4!
Old 01-08-2022, 07:59 PM   #15
Swedbrick
Swedbrick's Avatar
My lunchbox locker worked well, but boy were roundabouts and slow corners a challenge at times. Changed it out for the LSD option dl242 linked which I got from TurboDutch and it's much nicer to drive.
The LSD kit is only 25% lock however and will cause some silver in your diff oil, so not ideal for longevity, but the same was probably true for the lunchbox. The amount of wear on your spider gears will also affects it's working. For the lunchbox the diff center might not fit, which Sjeng encountered on his 16v build, requiring a different one.
A note of caution on the lunchbox for high hp is that is will lock and unlock when you go off throttle. I know a guy that managed to spin his 240 whilst racing a gtr that way, as he got slightly sideways off throttle and then hammered it. I also had some unintended sideways action on rainy days even with the N/A engine, although that could be considered a way of life if you are opting for welding as well
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
Old 01-08-2022, 09:04 PM   #16
rb92673
Thanks for the feedback. My car is 100% track only. It is not even legal for the street. I wouldn't consider it high horsepower either.
Old 01-08-2022, 09:36 PM   #17
mikep
The MP
mikep's Avatar
I was replying to the “cheap” request.
I have a locker, looks like a spartan. I have not tried it, and was going to send it to eric (badvlvo), but i can install it to try it out. I’m still a fan of clutch types as well as truetracs, but i am aware of the limitations of each.
Old 01-08-2022, 10:08 PM   #18
rb92673
I think the end state answer is a gripper, but I need to do a fuel cell first.
