![]() Im building a 93 240 drift car and im going to do rods and pistons. I thought about swapping the crank while in in there for 86mm and 2.5l of displacement. How much difference does this 0.2l make throughout the powerband? And is it worth it?
Specs: Ported 531 head 93 squirter block Yoshi rods pistons Holset he341 30 psi Enem k15 turbo cam E85 Haltech 1000 Kl racing turbo manifold and cast intake manny Do88 intercooler with 2.5 inch piping |
#2 | |
![]() Quote:
![]() 1990, Volvo 740 16v +T 1991, Volvo 745T 16V - crushed build thread: http://forums.turbobricks.com/showthread.php?t=249553 |
#3 | |
![]() Cast redblock cranks aren't exactly known for failing....
Cult Person. Pissing in your Kool-Aid. Quote:
#4 |
![]() I'm not sure anyone has any real data to answer the question but my thoughts on this:
I bought a complete boat engine for $100 and the 2.5l crank is sitting in my shed. If I ever have to build another engine/replace my current forged rods & pistons I'll certainly take advantage of it and build a stroker. I'm not sure I would spend ~$500 to buy a crank from someone else, though. side note: I have 158mm rods in my 2.3l with Wiseco pistons and the lighter pistons make a difference in how quick the car revs over the regular 156. |
#5 |
![]() Join Date: May 2004
![]() I'd comment, but really, have no experience with a stroker motor.
I do have a B20 in my old car with another .2(ish)L of displacement added to it, but that was with bore, not stroke, and AFAIK a stroke change will make more of a difference than a bore change. The .2L of added bore displacement didn't really add much in the way of peak HP, but did add torque, especially down low. And I think it has continued to benefit the HP as I've added other mods which raised the torque range. But that's normally aspirated, and I think the effects of .2L on a boosted motor would still exist, they'd just be relatively less important than all of the other aspects - efficiency of the turbo, how much boost, intercooler, intake manifold, etc. In other words, yes, it would make a difference, but so would turning the boost up another psi.
#6 |
![]() Join Date: May 2007
![]() Expect a specific output increase commesurate with the change in displacement. I'm swapping in a 2.5L block into my car, which would correspond in a ~20 lbs-ft bump in the 2000-3500 range where my current engine makes very little torque. You can expect a minimal improvement in spool time out of that turbo also.
If you are already forking over money for rods and pistons, figure out whether the incremental cost increase is worth the nominal performance improvement and go from there. |
#7 |
#8 |
#9 |
#10 |
#11 |
BRANDSCHUTZVORSCHRIFTEN!
![]() Join Date: Dec 2002
![]() speaking of, where are your 8000 rpm pulls?
I've had both cranks up to 8000+ rpms ![]()
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Now with in-house Dyno tuning! Megasquirt Tuning! |
#12 |
The MP
![]() *ABIGGERHAMMER has entered the chat
#13 |
#14 |
#15 |
![]() ~8% power increase from displacement alone + ~4% torque and power increase from longer stroke.
#16 |
#17 |
#18 | |
![]() Quote:
![]() Last edited by Harlard; 10-28-2021 at 06:01 PM.. |
#19 |
![]() As is customary, I fail to deliver:
#20 |
![]() typical.
#21 |
![]() The scene:
Harlard gets ready to make pull to 8500 and data log it, just to make Kenny proud. I patiently await the text about something breaking. |
#22 |
#23 |
#24 | |
Burnt Sierra Madre
![]() Quote:
brown line? |
#25 |
cone dodging dilettante
![]() what happens to power and RPM when you lift?
1993 944 B230FT/M90 thread here: http://forums.turbobricks.com/showthread.php?t=345277 2x 1991 245 B230F/M47 (LeMons car, street car) I sell chips for LH 2.4! |
