![]() Hello Turbo Bricks. I have a 1968 Volvo 142s with a b20 in it and su hs6 carburetors. It currently has a bw35 in it but I hopefully very soon will have swapped a m40 into it.
Anyway.. I have been rebuilding the car and I have been setting everything back to the specs in the Haynes manual. I was wondering if there any good cheap modifications or tuning that I can do to pump out a little bit more power from the 4 cylinder. I'm not trying to go crazy and I really don't want it to be too hard on the engine but I think it would be fun to play around with. ![]()
volvvovlovlvovovlovlvovlvovlvovlvovlvooovlovovovoo vl |
- Stock PSI Or Bust -
![]() No NA performance is't cheap.
Salaminizer
![]() Nitrous oxide. Jk
Don't they make cams for those things? Idk much about making the old ones faster with the original engine.
Feedback thread https://forums.tbforums.com/showthread.php?t=144924 1978 242, 5.3 L33 1979 242, MS, R brakes 2006 V50 T5 AWD @ 17 PSI |
#4 | |
![]() Quote:
Street Performance Camshaft - B18 B20 $275.95 https://www.ipdusa.com/Media/34597/Large/34597.jpg ![]() |
#5 |
![]() You are thinking too big... I was thinking like a good set of spark plugs or a timing advance or something like that. Or would that not do anything?
#6 |
![]() What would that camshaft do? That would be fun to tinker with as well.
#7 |
Salaminizer
![]() something like this probably
![]() Yes I have that book lol |
#8 |
#9 |
#10 | |
Bored Member
![]() Drive downhill exclusively.
![]() "Rear Wheel Drive, the way God intended. If a car is being pulled from the front, doesn't that mean it's being towed?" "Lister, you are a polyp on the anus of society." - A.J. Rimmer |
#11 |
![]() Lol
#12 | |
Professional Hack
![]() Stock B20s with dual carbs were rated at something like 100-115 SAE gross hp... the high-compression EFI motors were supposedly rated around 135 hp.
You're probably not going to gain much until you start doing headwork or a cam swap in the old OHV engines. The other option is just to lighten the car. EDIT: If you go the cam route, get a K or a D. Pretty much anything bigger (or hawg-aftermarket-y) is going to require headwork to take advantage of the extra lift. I went down this rabbit hole once.
Doing the wrong thing the right way. ------------------------------------------- Quote:
-------------------------------------------- - -1983 245 Diesel (Current Project) - passively for sale (interested in trades!) Last edited by fatcatbestcat; 11-27-2021 at 11:52 PM.. |
#13 |
#14 |
![]() So if I was to go with a camshaft, what camshaft would you choose? What would I gain from that? Would I loose anything to a camshaft? Is there anything else I would need to do besides installing the new camshaft and some tuning?
I don't fell like I need to make more power... I just think it would be fun to play around with. This whole car is getting restored but I'm also enjoying experimenting with the car. I've never done any of this b4. |
#15 |
#16 | ||
![]() Quote:
![]() Quote:
#17 |
#18 |
#19 |
![]() I do use ZDDP in the motor oil.
#20 | |
board member
![]() Quote:
Desperate need of elf assistant for interior work - Cash/Beer option $ Feedback thread: http://forums.turbobricks.com/showthread.php?t=323689 |
#21 |
Fought Covid and won
![]() What exhaust do you have? If you have the mechanical fan, switch to an electric. What base timing on your ignition? Sometimes you can add a degree or two and make it feel better, as long as it doesn't ping. If you don't know how to listen for ping, maybe not a good idea. What kind of ignition? OEM? or aftermarket? sometimes playing with the gap on aftermarket high energy ignitions can change the feel. As far as a cam, depends on your driving style. If this is a "around town" car, switching to a hipo cam will make it feel slower. Usually you shift the power higher up in the rev band and only feel it when you are driving hard. Unless you are shifting at 5k rpm all the time, be careful of switching cams. In my 740 (with V8) the current motor has a bigger cam, but since I shift under 3k rpm, the car feels slower than it did with the old "peanut" cam. If I run it hard I can feel the increase in power, but rarely do.
My first Volvo was a 68 142S, Bought it in 1981, fun car and miss it a little. Enjoy your ride
1985 Chevy TPI V8 740. ![]() |
#22 | |
![]() Quote:
![]() E-fans suck, and might not even work with a 35 amp alternator. |
#23 |
#24 |
Old and boxy but good.
![]() If it's a 140 that has the optional rear window defogger. Those cars got a 55 amp alternator. My 123gt had a 35 amp alternator. I had a 55 amp 140 motorola one rebuilt with an integrated regulator. Worked really well on there for many years. None of that was gonna run an efan though.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 435k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#25 | |
![]() Quote:
![]() Next thing you'll be telling us is that the other quintessential TB cut sprangz mod is the best thing since sliced bread & toilet paper. ![]() Last edited by Redwood Chair; 11-28-2021 at 11:59 PM.. |
