Old 12-02-2021, 12:05 PM   #1
durk80
durk80's Avatar
Default 1990 240 ATE caliper rebuild?
Hi all! My back caliper is weeping brake fluid. I saw on clean flame trap's website a rebuild on the fronts.I read about the remanufactued calipers with chrome plated pistons wearing out prematurely. How hard of a job would it be to rebuild them myself and would i need any special tools? Thanks!
durk80 is offline   Reply With Quote
Old 12-02-2021, 12:11 PM   #2
- Stock PSI Or Bust -
https://www.rockauto.com/en/catalog/...b,caliper,1704
how psi stock cna sprout?
Old 12-02-2021, 12:33 PM   #3
Radtap
Radtap's Avatar
It’s two seals and two dust caps, pull dust cap off piston, pressurize using air compressor to push pistons out, carefully remove seal from piston bore, install seal, piston then dust cap and done. Don’t separate two halves of caliper. Rebuild kits are available through iPD and FCP
Feedback
Radtap is offline   Reply With Quote
Old 12-02-2021, 12:43 PM   #4
OVERDRIVE
OVERDRIVE's Avatar
You won’t need any special tools, but compressed air makes it easier to push the pistons out. Sometimes you don’t know if the pistons have corrosion that can’t be cleaned up until you’ve taken your car all the way apart, so take that into consideration.
1990 244 DL AW70 189 Polar White -hers
1991 M5 668 Schwartz II over black nappa. -his
OVERDRIVE is offline   Reply With Quote
Old 12-02-2021, 01:45 PM   #5
durk80
durk80's Avatar
Thanks for the warning about splitting the calipers apart. I knew there was something i shouldnt do!
Old 12-02-2021, 03:06 PM   #6
durk80
durk80's Avatar
Are the original pistons aluminum and steel?
Old 12-02-2021, 04:33 PM   #7
nel621
IF you're lucky the pistons will come out with compressed air.
Old 12-02-2021, 06:23 PM   #8
No.
Old 12-03-2021, 12:29 AM   #9
Radtap
Radtap's Avatar
If second one doesn’t pop, install dustboot over empty bore and clamp a flat piece of steel to create a seal that allows other piston to pressurize
Old 12-03-2021, 02:01 PM   #10
283SD
Using compressed air is dangerous, if they are that stuck, I had a friend that almost lost a finger when the piston popped using compressed air. I use a grease gun with a hard line to the caliper to push out the pistons, put a piece of steel in the rotor slot the size of the slot so that each piston will stop before it comes out of the bore. If you are rebuilding them anyway,clean/blow out the grease and brake clean them, clean the groves and the bore of rust, use a good brake lube when you put them back together.
Old 12-04-2021, 04:46 PM   #11
Radtap
Radtap's Avatar
Stick a wood block in between the pistons, I mean just don’t stick your hand inside a caliper meant to stop cars lol
Old 12-05-2021, 02:42 PM   #12
durk80
durk80's Avatar
Love this idea, Radtap and 283SD, as well as placing a block of wood between to keep everything nice during the extraction process.
Old 12-05-2021, 02:57 PM   #13
durk80
durk80's Avatar
No.
What a drag! I couldn't find any that were just stainless. The Rock Auto description said that they were made of stainless and aluminium, and I went ahead and bought them just in case the pistons are gone. Although, if I have to use those new ones, it sounds like I'll be rebuilding them again in no time. The brake lines have been filled with rust in the past and probably still have some residual rust. I've flushed them at least 4 times, and at least twice it was done by a mechanic when he installed poly bushings and replaced some hoses.Thank you for your insight!
Old 12-05-2021, 03:14 PM   #14
Pretty sure the stockers are steel.
Old 12-05-2021, 03:28 PM   #15
Radtap
Radtap's Avatar
Why not just replace the brake lines at that point? I'd be worried about rust eating through a brake line. There's likely contaminants left in the brake system that can cause future issues.
Old 12-05-2021, 04:15 PM   #16
2manyturbos
They are.
Old 12-05-2021, 09:53 PM   #17
If the dust boots are torn they're probably cores / trash anyway, so take a look before you go too far down the 17¢ /hr rabbit hole and have to buy a rebuilt caliper anyway.
Old 12-06-2021, 03:56 AM   #18
Kjets On a Plane
Kjets On a Plane's Avatar
^This.
There's an outfit in Utah that does real nice work on the NLA ABS calipers if you send them good cores, but it ain't TB cheap, either?
How PSI a stock can support?
Always Be Crushing!
Old 12-06-2021, 10:03 AM   #19
283SD
Farrell Stainless Steel Pistons. The # I have for them is 1 631 454 1977, haven't used them in a while.
Old 12-06-2021, 10:54 AM   #20
mikep
The MP
mikep's Avatar
I only use a grease gun if one is VERY stuck. Clamp the free one in place, pump until the stuck one is almost out. At that point you are also looking at honing, so it needs to be split, making the grease mess less of an issue.
It was a Datsun, it was more likely rust in something ...
Originally Posted by propav8r View Post
Ain't my couch.
F*ck that couch.
Old 12-06-2021, 12:25 PM   #21
Default It's Really Not That Hard
'Exercise' them on the car and if they don't come back to life replace them.
