rearwheelpeel
Slow Learner
- Jul 22, 2014
- Rochester NY
Are all year 240 water pump pulleys the same? I want to get one to have powder coated, or maybe get the aluminum one that KL racing sells. I?ll be putting it onto a 1976 b21.
I prefer the large diameter and reinforced pulleys for racing. What you have should be the large diameter, the turbo engines got a smaller diameter pulley for more water pump flow (not needed IMO).
would the introduction of an underdrive pulley at the crank influence that thought at all?
Small pulley is good for the 700Ts that would idle with the A/C on in their day with a lot of heat soak with the water cooled turbo/same size radiator etc.
Only came on the B230FT cars.
Lot of overheats on those in routine use.
That said, the small pulley cost me a couple heater cores over 4500RPM & isn't really helping.
B230 have a larger crank pulley than B21/B23. The non-reinforced & couple years only ~late 82-early 84 pulleys I've seen shatter...sometimes?
Only those years...not sure what happened there?
Tropical fan clutch + pusher fan at idle is about max traction & surface area/grip of alt + WP about equal to the B21/23 crank pulley with everything in good shape/stock dual belts.
