iwannadrive
- Mar 20, 2010
- Minneapolis, MN
So,
I've got a 1968 Volvo 122s 2dr. Currently stock. I'd like to drive it hard.
(no, I don't think you understand what I mean. I'd like to drive it at 10 or 11/10's when I want to, without mercy.)
My 122 is on very sedate 165-width tires at the moment, and I don't see myself going to anything much more than a 185 or 195 width, if I were to build widened steel wheels for it. I like originality, along with having lower traction limits, so I can drive like an ass without killing myself.
SO, how much am I pushing my luck if I drive mine like this?
I'm not planning on shoving a ton of power in the car, likely not more than an honest 130bhp at the most. But I need to be able to manhandle the car when I want to, without worrying about wheels falling off and an axle stub digging into the ground. I'd also like to autocross it, for giggles.
I'd prefer to keep the standard 5x4.5 bolt pattern and original or widened amazon steelies, so I'd rather not go to an 1800 rear axle if possible. Plus, less time up on stands means I have more time to drive it... the car is my warm-weather daily.
On the other hand, I do need to completely go through the rear brakes, so now is a good time to address this question, before I spend money twice.
Does anyone race their 122 with the stock tapered rear axles? Just kind of looking for data points here.
Anything else I need to be aware of when pushing a 122 hard? I've seen the oil light flicker under hard cornering a few times, which is very scary. (I'm hoping this is mostly due to the ridiculous amount of body roll. Replacing every single suspension bushing is on the short list of things to do, which I'm sure is adding a lot of compliance. Then taking stock of what spring rates/shock damping I'd like to go with.)
