Old 09-03-2018, 10:21 AM   #1
Texas240
Prius Owner
Texas240's Avatar
Default Volvo R brakes on 240 pedal feel issues
Ive been battling pedal feel issues for a few years now since I've put the brakes on. The first motion of the pedal I have nothing, maybe a little braking then I start to get braking. I get full brakes at the very end of the pedal movement. Ive tried a few different known good boosters, tested with a mittyvac pump to check of leaky seals and Ive switch over to the mustang master cylinder.
Generally I dont complain in dry condition, I have great breaking other then the pedal feel. When its braking in the wet, tires just lock up, same ****ty pedal feel or lack of pedal like in the dry condition then brakes just lock up unless you gingerly apply brakes. What are other peoples pedals feel like with the R brakes on the front and the mustang master?
93 245 LS Engine Swap Project
Old 09-03-2018, 10:58 AM   #2
freevolvos
freevolvos's Avatar
what bore master does the rb use?
Old 09-03-2018, 11:34 AM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
So you had the same issues with the stock old Volvo MC and then a new Mustang MC?
thelostartof is offline   Reply With Quote
Old 09-03-2018, 12:03 PM   #4
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Have you already played with the pushrod adjustment?
Old 09-03-2018, 01:54 PM   #5
John V, outside agitator
What is the piston size(s) on the calipers?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-03-2018, 06:02 PM   #6
GTJordan
Been here for too long
GTJordan's Avatar
Leading Piston Size: 42mm (2 of each)
Trailing Piston Size: 38mm (2 of each)
REAR BRAKE CALIPER PISTON DETAILS:
Leading Piston Size: 28mm (2 of each)
Trailing Piston Size: 30mm (2 of each)
I found this on VIVA's site.
Old 09-03-2018, 06:28 PM   #7
freevolvos
freevolvos's Avatar
i would start with what the volvo r used for a master cylinder, what bore for what your using power/no power assist, then check pushrod, then pedal ratio, when i put the big brakes on my Chevy all of these things bit me in the ass, and a used hydro- boost that was slowly applying the brakes when it was running
Old 09-03-2018, 07:23 PM   #8
Texas240
Prius Owner
Texas240's Avatar
I had this same problem with my mazda rx7 brakes with stock Volvo MC when I went from manual to auto then same issues with the Volvo R front calipers. This was also with a new volvo stock master.
Yes, but this has been in the back of my head.
I'm using the exact master Volvo R is using
Old 09-03-2018, 08:41 PM   #9
freevolvos
freevolvos's Avatar
do you have a build thread on the brakes?
Old 09-03-2018, 08:45 PM   #10
MDVLN
MDVLN's Avatar
If you're adjusted fully outwards and it's still not enough, here's what Marv did (Similar to Homer when he ran the Porsche Calipers IIRC). Do note that Marv is running the Cadillac ATS style Brembo calipers on the front of this car(wagon), though. I figured it's worth mentioning before getting further into the system and having to deal with bleeding the brakes a few times.
Originally Posted by Marvelous3 View Post
Turns out all I needed was a small rod coupling on the brake booster rod. The stock rod is too short to actuate the mustang master cylinder. Id probably bled a gallons worth of brake fluid through the brake system thinking i had the process wrong or that there was somehow still air in the brake system.
The stock rod on the booster is sae thread so I was able to find a sae to npt stud at my local ace hardware. So purchased a new stud and then a 3/4" length rod coupling gave me the needed length to actuate the master cylinder when I pressed on the pedal. Finally, a stiff brake pedal.
WP_20160523_001
I spent yesterday evening playing with the rod length. It was too long at first so the brakes were dragging. That's one way to bed in the new pads i guess. But I was able to get it really dialed in.
Old 09-03-2018, 09:03 PM   #11
Texas240
Prius Owner
Texas240's Avatar
Did exactly as Homer did with his extension
Old 09-03-2018, 09:04 PM   #12
MDVLN
MDVLN's Avatar
Ah, word. I'm pretty much just echoing what freevolvos is saying though so, cheers. Unfortunate that the problem may lie deeper.
Old 09-03-2018, 09:12 PM   #13
M.H. Yount
M.H. Yount's Avatar
I realize many of us are asking 'problem obvious' questions....but, here we are. Did you bench bleed MC's when you replaced them?
Old 09-03-2018, 09:52 PM   #14
Marvelous3
Who engineered this?
Marvelous3's Avatar
The rod length is important to get right. If you haven't you need to replace the adjustment screw on the end of your brake booster rod. The stock rod isn't long enough to work with the mustang master.
Old 09-03-2018, 10:17 PM   #15
Texas240
Prius Owner
Texas240's Avatar
read bellow.
Yes
Old 09-04-2018, 01:05 AM   #16
Originally Posted by GTJordan View Post
Leading!!!! Piston Size: 42mm (2 of each)
Trailing !!!! Piston Size: 38mm (2 of each)
Veeeeeeeeeeeeery interesting , Schmart...
But EVERY progressive piston caliper---and those sizes are common as hell, and perfect--but I've already been banned like 3 times by that guy Mr Super Nice Guy up there in your neck of the woods just on piston sizes so I won't say more about that----
EVERY progressive has smaller piston FIRST...because as a n AP Racing injur-near once siad "First piston gets a nicer "bite" on the disc with longer pads so 1.5" first, then the trailing at 1.625"
Always
Old 09-05-2018, 10:37 AM   #17
freevolvos
freevolvos's Avatar
let us know if you get this figured out I'm interested in what causing the issue
Old 09-05-2018, 07:32 PM   #18
Texas240
Prius Owner
Texas240's Avatar
We did the math and we think I that I bought the wrong bore size mustang master cylinder comparing the stock 240 one vs. the s60r/v70r the one I have is too small so I've ordered a 1-1/16th inch bore.
Old 09-11-2018, 10:37 AM   #19
freevolvos
freevolvos's Avatar
the smaller the bore the higher the pressure in the line, i hope this solves your problem, a lack of fluid Volume sure would cause a lazy pedal to and i would think a high pressure situation would cause grabby brakes, low pedal
Old 09-11-2018, 10:43 AM   #20
stick70
All the gauges
stick70's Avatar
I've had no pedal issues with my r brakes all around and mustang master
I will say my pedal is a little touchy. Not lock the brakes up touchy, but someone that hasn't driven the car will find the pedal sensitive.
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '60 Coupe DeVille -- '84 Rabbit GTI
Old 09-11-2018, 11:01 AM   #21
J_Jones
J_Jones's Avatar
Same experience. Ended up switching to the earlier, smaller, single-diaphragm booster and think it is just right with the mustang master and caddy calipers.
J_Jones is offline   Reply With Quote
Old 09-11-2018, 11:29 AM   #22
stick70
All the gauges
stick70's Avatar
Do you know approx what years I should be looking at for this?
Old 09-11-2018, 12:54 PM   #23
J_Jones
J_Jones's Avatar
I got mine from Rockauto, A-1 CARDONE 535890, that was for a 1977 240. Looks like they are currently out of stock though. Maybe one of the fellas that services the wanted adds on here will have one on their shelves?
Old 09-11-2018, 11:04 PM   #24
Texas240
Prius Owner
Texas240's Avatar
Mine is the opposite of that. I have the new mustang master here with the bigger bore but have yet to install. Im still in the middle of a custom wooden barn door build. Hoping to get to the swap in a few days.
Old 09-12-2018, 07:44 PM   #25
lummert
lummert's Avatar
When I tried using a larger that stock master cylinder (Ford F-Series) on my 88 765 with Jumbo brake upgrade the brake pedal was nearly impossible to press, the pedal was rock hard. I installed a 2000 Ford Ranger master cylinder with 1.0625 inch bore and it was a good option. A 1/16 inch difference in bore size makes a huge difference. I also learned that the 700/900 cars with Jumbo Brakes used a brake pedal with a different ratio. So matching the brake pedal ratio to the master cylinder is a good idea.
