#2576 | |
Turbo, what?
![]() Quote:
Kyle - NLMGG: '91 244 NA Toy - General Leif: '71 142 Endurance Racecar - The General's Facebook - Oregon Volvo Tuners - Died ![]() |
#2577 |
It's a girl!
![]() If you're looking for something fun to do, a fun change to your car, for free, weld the diff. It's not like it's permanent (unless you get slag in the bearings). If you drive it for a few months and hate it, save up for an LSD or G80. But for the short term it's a hoot! It's not like your car is particularly grandma friendly, that was my biggest complaint about the welded diff in my 242 (which I daily drove for 3 years with a wife and baby in), was the chirp chirp chirp in parking lots and the inside wheel skipping/studdering. But at more than 5mph it's fine. The first time you turn the wheel at parking lot speeds you will DEFINITELY feel the understeer, I can still remember that time, the steering wheel requires more effort, but you just compensate and get used to it over time.
Do it. It's practically free and you'll get to do some mad drifting. Doing donuts in a car with a locked diff feels completely different than an open diff, like a pendulum with your front wheels being the pivot. You'll love it!
'83 242 '95 T5R '98 S70 |
#2578 | ||
Hnnnnnng
![]() Quote:
1990 745tic 1984 244DL (parts) 1989 245 slicktop M47 drift missile- ratty as hell 1967 220 amazon station wagon. 1990 244GL M47 summer DD project. Quote:
Poopie scissors
#2579 |
![]() Hmm... If I can find a spare diff, that's actually sounding pretty tempting now. I'm sure it would help a lot with winter traction too... Hmm.
You now have my permission to weld the diff, Jerd. ![]()
#2580 |
![]() hahah im sold ill do it before davis then everyone can lol when i spin out at the autocross.
#2581 |
It's a girl!
![]() In snow you have to learn pretty quickly how to manhandle the car when sideways, because it will get sideways. A LOT, sometimes even when you're not asking for it. It's a bit scary to decel in gear down a steep icy/snowy hill and feel the back end start stepping out
![]() God I miss my 240, been daily driving my 850 for 6 months this winter. I mean e-brake turns in teh snow are fun but nothing compared to RWD. |
#2582 | |
tvåförti
![]() Quote:
I almost wrecked in the beginning of the winter when I downshifted into 2nd gear at about 50mph entering a turn on a narrow forest road. ![]()
'88 Volvo 245 - LH2.4, M47
'20 Volvo V90CC - D4 AWD '64 Ford Taunus 17M, '78 Fiat 126P |
#2583 |
Bad for Babies
![]() ^^^ Hey, get back under your rock!
Welding it is better than open but can really suck autocrossing if you don't learn what the car is going to do with both rear wheels spinning the same speed all the time. Keep a small rear bar on there with the welded, a little lift of the inside tire will do you some good exiting the corners. It will spin a little, it's travelling a shorter distance than the outside tire, but lifting it a bit will lessen the desire to slide until you go heavy on the pedal.
RIP BADVLVO 3/1/1980-10/10/2015 Died at age 35 1988 244 |
#2584 | |
![]() Quote:
#2585 |
Do you have a cobalt?
![]() Join Date: Nov 2005
![]() i wouldnt do it if your a auto x lover i would just jump to a g80 for 100 dollars. welded gets old fast..
1983 242dl *6.0 lq4 swaped* Build thread http://forums.turbobricks.com/showthread.php?t=282323 |
#2586 | |
![]() Quote:
#2587 |
![]() im really not that big into auto x any more. Local club sucks ass and the car really took a turn in a different direction i am no where close to competitive.
#2588 |
#2589 |
![]() They're still using your car on the flyers. :P
#2590 |
![]() Got the car running again. Waiting on Josh's boxing plates to pull the front apart put poly bushings in and replace the tie rod ends.
#2591 |
![]() With weight in the back i was getting a weird noise coming from the drivers side rear tire. It was rubbing.. So i Jacked it up today pushed the fender out a bit, smashed it in with a hammer and adjusted the pan-hard bar one turn to the passenger side. I then cut a little more off the jeep springs to get it to sit about another 1/4" lower in the back. I need to order coilover springs and get the adjustable seats on... The car looks a little better and feels like it puts power down slightly better tempted to take the bump stops off and go a bit lower. As if i had not cut my bump stops it would be sitting on them and even though they are cut there is only about 1.5" of travel before they hit.
#2592 |
![]() Can we get some pictures?
#2593 |
![]() Ill snap some tomorrow Before class.
#2594 |
![]() Seems like my power steering rack is going out... Thinking about looping the lines.
#2595 |
Turbo, what?
![]() What makes you say so?
#2596 |
![]() Difficult to discribe. Its a very unpredictable feeling. One while turning the wheel there is a patch in the rack that is rough non assisted..
belts tight fluids filled hoses are tight no leaks on the rack.. cant think of the problem being anything other than a seal in the rack. |
#2597 |
Turbo, what?
![]() Ah, ok. Yeah... Does sorta sound like it then. I'd still just run it until it's more dead or you can find a replacement. I know you won't like turning those 245s...
#2598 |
![]() Yah i pm'd towery on his opinions. I might loop it just to try out of curiousity but either way i have a feeling ill be replacing/rebuilding the rack because i like powersteering.
#2599 |
Rad Panda
![]() Check your steeting u joints?
‘02 V70xc ‘96 F350 ‘93 525it ‘88 325is ‘84 533i ‘79 242 |
#2600 |
![]() Before you bother looping it, just try taking the belt off for a quick taste... Effort will be the hardest it ever will be, but its a quick way to tell.
1983 242 ICSCC GP Race Car |
Thread Tools | |
Display Modes | |
