Closed Thread
Old 04-18-2011, 07:12 PM   #1001
Karl Buchka
Torque tube:
Transmission side is on the left.
You can see the hole for the selector rod here:
The bellhousing bolts to the outer circle and the hydraulic throwout bearing is attached to the two inner holes:
The entire assembly obviously needs to be shortened quite a bit. We haven't done any measuring yet, but we're hoping the input shaft length and torque tube bolt pattern allow for a simple adapter plate arrangement with the 960 bellhousing.
Karl Buchka is offline
Old 04-19-2011, 11:38 AM   #1002
Poik
Backwards Turbo
Poik's Avatar
Why do you think it needs to be shortened? I would think you could position the engine so that you wouldn't have to modify it at all. The difference in wheelbase between the C5 and the 240 is less than 1/4", and the vette has the engine sitting well behind the centerline of the front wheels.
Edit: no hot linking: http://corvetteactioncenter.com/gall...c5chassis4.jpg (copy and paste)
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline
Old 04-19-2011, 03:37 PM   #1003
Poik
Backwards Turbo
Poik's Avatar
Also, looks like it uses the same throwout bearing as the LS1 f-body T56.
http://www.ramclutches.com/corvette/...tube_front.jpg
http://www.wilcap.com/T56.JPG
Input shaft should stick out a good inch or more longer than the T56 since it doesn't have that recessed area. You guys can borrow my jig thing too, just needs a 5.000" hole in a plate.
Poik is offline
Old 04-26-2011, 06:13 PM   #1004
Karl Buchka
THANKS Eric. You're a doll.
In other news, here's what a "permanently sealed" STS-V/C5 Corvette hub/bearing assembly that's been permanently disassembled looks like. Turns out they're more user serviceable than Timken would lead you to believe.
Pop off the ABS sensor cover, pull the ABS trigger wheel off, then remove this two-piece retaining ring. After that it presses apart easily (too bad we didn't figure this out until after we had wailed on it in a 40 metric ton press).
Disassembling the hubs makes it easier to modify the bolt pattern and center bore.
And a CAD update. Alex did a ground-up redesign of the front brake calipers. The basic piston layout and pad is the same, but these are lighter, easier to machine, use smaller stock, deflect significantly less, and look about 100x more bad ass than the old ones.
Old 04-26-2011, 07:08 PM   #1005
550
I came at that cad drawing.
Joe Bieda
V.C.O.A. Midwest Chapter President.
1984 242 M46 GLT.
-Couple of things done to it
1998 S70 Auto.
-LONG history.
1983 242 M46
Check out http://JJFAB.net For your K24 CBV blanking plates and oil feed/return flanges!!
550 is offline
Old 04-26-2011, 07:39 PM   #1006
The Aspirator
It's a girl!
The Aspirator's Avatar
Yes, yes they do. Now that I can't wait to see being machined, TAKE VIDEO!
'83 242
'95 T5R
'98 S70
The Aspirator is offline
Old 04-26-2011, 07:55 PM   #1007
WillettRun?
†John3:16
WillettRun?'s Avatar
Sweet, it looks really nice! I'd like to see the finished product!
I still love Jesus and He still loves me.
MaxxECU Dealer/Tuner
WillettRun Automotive, LLC
WillettRun? is offline
Old 04-26-2011, 08:31 PM   #1008
towerymt
the real Towery
towerymt's Avatar
I hope you maintain the color scheme of the CAD when it goes to production.
towerymt is offline
Old 04-26-2011, 09:00 PM   #1009
Poik
Backwards Turbo
Poik's Avatar
I hear they are going to make their own carbon/carbon rotors.
Poik is offline
Old 04-26-2011, 09:30 PM   #1010
towerymt
the real Towery
towerymt's Avatar
start sintering now and you'll be done by the time the car needs brakes.
towerymt is offline
Old 06-11-2011, 11:09 PM   #1011
Karl Buchka
It's nice when stuff just bolts together.
Cursory measurements indicate that the torque tube should work perfectly as-is. Pretty excited about that.
Old 06-11-2011, 11:13 PM   #1012
Poik
Backwards Turbo
Poik's Avatar
See post 1002.
Poik is offline
Old 06-13-2011, 09:20 AM   #1013
ashvolvo
2 > 7
ashvolvo's Avatar
Excellent work!
I really enjoy reading the updates. Keep them coming.
If you're interested, check out the V8 Supercars Car of the future blog -
http://www.v8supercars.com.au/cotf/t...4/default.aspx
Also good reading.
Cheers.
Likes good coffee & fast volvos. Builds stuff. Races stuff.
f: https://www.facebook.com/DvsPerformanceParts
twitter: ashd61 | w: http://www.dvs.net.au
1998 V70T5
2004 Holden Commodore wagon
ashvolvo is offline
Old 06-13-2011, 03:01 PM   #1014
240_brick
Do you have guidance pins on your upright adjustment or is it's position entirely fixed by the screws?
240_brick is offline
Old 06-13-2011, 04:05 PM   #1015
Karl Buchka
Thanks Ash. That's a cool blog. Just added it to my reader.
240_brick, if you look closely at the cad drawings you can see there's a "track" for the mounting block to ride in.
Old 06-14-2011, 01:27 AM   #1016
socalsean
back in the game
socalsean's Avatar
Delicious as usual. I can't wait for seconds.
socalsean is offline
Old 07-30-2011, 10:00 PM   #1017
Curt_pnw
bumpity bump. anything new?
GARAGE | 85 245
Curt_pnw is offline
Old 07-31-2011, 12:50 AM   #1018
Scandia
Unfamiliar with a torque tube. . . . .& when you say the tranny's going to be in the back, how far back ? is that the tranny & the rear dif bolted directly together ? Appreciate the info.
.................Dave
Scandia is offline
Old 07-31-2011, 01:31 AM   #1019
towerymt
the real Towery
towerymt's Avatar
trans at the back with the rear diff. imagine you split the bell housing from the trans, put the torque tube in between.
towerymt is offline
Old 08-14-2011, 11:01 AM   #1020
Karl Buchka
Just realized this thing got bumped a while back. Spent the summer getting a new workshop space in order, so we didn't get much of anything done on the 242. Same old story.
Back in Sweden now. Got lots of new ideas and new concepts to work through, time permitting.
Old 08-14-2011, 01:26 PM   #1021
YLD244
YLD244's Avatar
Interested to see how u are going to setup the rear suspension with the cv joints and hubs.
YLD244 is offline
Old 08-14-2011, 02:10 PM   #1022
WillettRun?
†John3:16
sequential lh fueling
Old 08-21-2011, 06:47 PM   #1023
Tom Wiley
So nothing is getting done.
Tom Wiley is offline
Old 08-23-2011, 12:33 AM   #1024
slacka_6
slacka_6's Avatar
sweet build im on board!!!!!
90 740 15g,3"turbo back w/magnaflow ss bullet,k&n,ipd sways&springs-blown up not forgotten
89 760 5.0L T5 4.10,SVO hurst st,B&G springs,braided ss fuel lines, 255LPH walbro pump, gt40 exploder intake,BBK billet fuel rails 30lbs injectors,92GT ecu,maf convert,dual 2.5" in to 3" out,ipd sway F&R,heim sway link mod,msd dizzy,CAI,K&N,17"escape steels 4 sleeper look,braided ss caliper hoses,eclipse stock look radio. carbon fiber wrap cause the paint sucks. more soon m90?E85?twin turbos?
slacka_6 is offline
Old 01-12-2012, 01:29 AM   #1025
Karl Buchka
The measuring stick and the plywood square: the latest in a long line of high tech tools developed specifically for this project.
Closed Thread
