#1 |
![]() Hello once again. I've got a 92 240 wagon. I started to close the hood and the hinges bent. The hood doesn't look like it's bent but after I closed it only the first latch releases. I took the grill out when I had it open...... so I have some access but I cant get the other pin with the spring around it to release.
Does anyone know how to get it to release? Edward |
#2 |
![]() After researching the Bentley's manual I see that what is not releasing is called the "hood latch pin". But it doesn't tell me how to get it to release.
#3 |
- Stock PSI Or Bust -
![]() Pry it over with a big screwdriver while someone pulls the release lever.
#4 |
![]() If all else fails and you can get hood open just a little, you can always take a 10 mm wrench and remove the bolts holding the lower section of the latch.
#5 | |
board member
![]() Quote:
a) push down on the hood b) after nose of hood is down have helper pull and hold release lever c) then pull up on hood The only other option I can see is either what RWC or Nel suggested ![]()
Desperate need of elf assistant for interior work - Cash/Beer option $ Feedback thread: http://forums.turbobricks.com/showthread.php?t=323689 |
#6 |
Enough already!
![]() After you get it open, it'd be a good idea to oil the hinge points.
Differences of opinions should be tolerated, but only if they're not too different. - Sharon Craig |
#7 |
![]() Be thankful you removed the grille first.
#8 |
#9 |
![]() On mine I was able to reach up behind the bumper with a long flat nose and pry the steel bar that latches around the pin. Once it was open I swapped it with a new one from a later year and adjusted it.
#10 |
Thread Tools | |
Display Modes | |
