Old 11-21-2021, 01:11 PM   #1
Dvroofer
Dvroofer's Avatar
Default Rim repair
Duplicate post. Sorry
File Type: jpg BFA5306E-D0AD-4CFB-85B6-837F080A9958.jpg (192.1 KB, 151 views)
File Type: jpg 06840450-37A6-454A-B933-D1A646FC0F90.jpg (179.7 KB, 146 views)
File Type: jpg 206CC791-028A-439F-9041-DA115914798C.jpg (113.6 KB, 143 views)
File Type: jpg 1BB725C9-BD82-4050-88ED-15113993996C.jpg (194.1 KB, 143 views)
Dvroofer is offline   Reply With Quote
Old 11-21-2021, 01:12 PM   #2
Dvroofer
Dvroofer's Avatar
Default Rim repair
Attachment 19306
Attachment 19307
Attachment 19308
Attachment 19309
I found these today but one has a little gouge. Looks like the tire on it is holding air. What do you think? And what do you think about repairing it. Cost? Process? Worth the junkyard cost?
Old 11-21-2021, 02:09 PM   #3
Dvroofer
Dvroofer's Avatar
Bought em for 200$ out the yard. One needs some work
Old 11-21-2021, 02:27 PM   #4
rearwheelpeel
Slow Learner
rearwheelpeel's Avatar
Seems like a good deal to me. At the dealership I work at they have a guy that comes around and fixes stuff like that pretty quick. I’ve seen him fix way worse. I had the wheels currently on my 240 straightened and he fixed all the curb rash for 200 bucks. If I didn’t work at the dealership it would’ve probably been around 100 bucks per wheel to straighten and clean up minor damage.
rearwheelpeel is offline   Reply With Quote
Old 11-21-2021, 02:28 PM   #5
matt b
AWRS, they come to you. But that may need more than they can do.
Old 11-21-2021, 03:12 PM   #6
- Stock PSI Or Bust -
That repair is probably going to at lest double the cost of that wheel set unless you have a connection.
how psi stock cna sprout?
Old 11-21-2021, 03:16 PM   #7
Fill with weld, grind, smooth and repaint.
Old 11-21-2021, 03:38 PM   #8
Dvroofer
Dvroofer's Avatar
Considering I almost bought the really nice set that’s been redone professionally for 1200$, even with the repair it’s about the same as shipping would of cost me from the east coast for the set. Do you think 200$ would fix it?. Worst case I find one more. All kinds of yards down here.I’d be up for filling and grinding. That I could handle I believe.
Thanks for all the input.Ive never had a rim that was damaged so I have no clue what the cost might be
Old 11-21-2021, 03:51 PM   #9
On a shoestring you could bondo it up and sand it down yourself.
Old 11-21-2021, 04:05 PM   #10
alschnertz
Enough already!
alschnertz's Avatar
I realize you're inquiring about more severe damage, but if it helps any, I had S40 rims straightened at a place called Alloy Wheel Repair Specialists https://www.awrswheelrepair.com a few years ago.
It was $100 each.
Old 11-21-2021, 05:26 PM   #11
vlvosavr
Close. Use JB Weld. Clean them up with alcohol and a brass toothbrush and have at it, file and sand. Put a piece of hard plastic behind that notch for a backstop and build it up with 2 or 3 applications.
I've done several wheels this way, the last a set of 19" from an Audi SUV . Guy managed to curb-rash all four, two of them worse than yours. I fixed them up and repainted them, they came out Absolutely Perfect. Gave him a talking-to about cutting corners too close.....
vlvosavr is online now   Reply With Quote
Old 11-24-2021, 12:08 PM   #12
Dvroofer
Dvroofer's Avatar
Jb welding it today. I’d like to run these on my 91 240 wagon: any suggestions on spacers or any modifications I might need for the fenders. I’m running koni yellow struts upfront with billstiens in the back with ipd sport springs all around and the bigger ipd sway bar set. These are 17 x7.5.
Old 11-24-2021, 02:57 PM   #13
That depends on the offset, tires and how much you want to bend up your shell.
Old 11-24-2021, 05:13 PM   #14
Dvroofer
Dvroofer's Avatar
They are 43et and I like to drive it! Tires I’m looking at maybe 225 45z, but open to the best recommendations from people with experience. So something manageable. I’m not opposed to learning how to roll fenders but would rather keep some clearance.
Old 11-24-2021, 07:28 PM   #15
90volvo
I have the same wheels on my 240. I think I have 1.5 in front and 2 inch in the back. In fact I believe I have a whole set of spacers left. Cause I had to buy a set of 4. Ill check and get back with you.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 12-07-2021, 05:14 PM   #16
Dvroofer
Dvroofer's Avatar
repaired the chippped rim with jb. Let it sit a week. Filed it down sanded and actually had pretty decent matching paint. Looking at tires online. Toyo, pirelli are decent priced right now any suggestions on brand or type from experienced Volvo owners? Looking at 225/45 17s
Old 12-07-2021, 05:26 PM   #17
tjanson
tjanson's Avatar
Are they still straight? Find someone with a TIG welder to fill, if you prep the area it won't take them more than 10 minutes. File/ die grind it smooth.
1993 245 DL - OEM+ Project
tjanson is offline   Reply With Quote
