Old 12-16-2021, 10:31 AM   #1
vxracer
vxracer's Avatar
Default I found a 92 245 for sale near me
Hey all!
I found a low mileage silver 92 245 DL locally. It is in fabulous shape. Apparently, it has 22,000 miles. Not so sure about that, but the condition of the car wont argue with that. I popped the oil filler cap off and see silver inside the motor, so definitely low miles. Apparently, it is a one owner car its entire life, and recently purchased by a friend of mine. But, it isn't cool enough for a kid, so I was asked to make an offer. If I don't end up with it, another Turbobricker lives nearby. One of us will end up with it.
I know the prices have gone up on these, and the condition makes it a great deal. Any idea what I should offer? I don't want to low-ball and miss it. KBB says 100 to 800 dollars. Some of these are fetching into the thousands these days. Wow
vxracer is offline   Reply With Quote
Old 12-16-2021, 08:52 PM   #2
white855T
Ask what your friend paid and go from there.
Old 12-17-2021, 12:38 PM   #3
vxracer
vxracer's Avatar
Thanks, yeah trying to follow up on it. No info. yet.
Old 12-17-2021, 04:34 PM   #4
Mr. V
Mr. V's Avatar
To my mind, if it is as pristine as you paint it to be, it's worth over three grand.
Anything less is a steal and a rip off of your friend.
Old 12-17-2021, 04:38 PM   #5
- Stock PSI Or Bust -
Default Poverty Thinking
Or $30K + on BAT.
how psi stock cna sprout?
Old 12-17-2021, 07:05 PM   #6
cmsuter
cmsuter's Avatar
I would be very weary. Odometers are known to break on these things. Just saying that the motor looks good when you pull the oil cap off doesn't really mean all that much. Really look at over for bushings, check if the hoses feel nice and soft, oil leaks, etc. 22,000 mi on a 30-year-old car means it sat a lot. Could be a gold mine, could be a nightmare. Just be smart
cmsuter is offline   Reply With Quote
Old 12-17-2021, 11:17 PM   #7
lyonsfin
If you pass, I am interested. Without seeing pics value could be $3k-$8k
lyonsfin is offline   Reply With Quote
Old 12-18-2021, 09:54 AM   #8
Marvelous3
Who engineered this?
Marvelous3's Avatar
$1500 and a 24 pack of keystone is fair for most **** box 240’s.
2016 Chevrolet Silverado 1500 Blackout Edition
1991 245+Turbo 16 Valve Microsquirt
Need Lawncare service in Atlanta? PM me for a lawncare and maintenance quote
Old 12-18-2021, 03:21 PM   #9
$500 tops on here.
Old 12-18-2021, 06:49 PM   #10
Marvelous3
Marvelous3's Avatar
$500 tops on here.
Gotta keep up with inflation man.
Old 12-18-2021, 07:20 PM   #11
Or keep buying $500 field rats that need $5K in R&R and an ~$8K + V8 swap.
Old 12-19-2021, 06:00 PM   #12
Janspeed
If it really has a genuine 22k mi on the odo it should be visible on the steering wheel, pedal pads, carpets, left seat bolster on the driver seat. They all should be in top condition. No wear visible. Same for the shifter boot.
Other pointers: headlight and windscreen glass, should be without scratches and/or pitting
Front edge of the hood: should have no or only minimal stone chip marks
Old 12-21-2021, 09:05 PM   #13
vxracer
vxracer's Avatar
I found out the paid 2,500 dollars for it. And the timing belt was just replaced about 40,000 miles ago. It is in very clean shape, garage kept, and a one owner car.
Old 12-21-2021, 09:43 PM   #14
Mr. V
Mr. V's Avatar
Huh?
It only has 22K milles on it but the timing belt was changed 40K ago?
Does not compute.
Old 12-21-2021, 10:00 PM   #15
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
I'd hardly call that "just replaced" anyway...
I sell chips for LH 2.4!
Old 12-21-2021, 10:02 PM   #16
Marvelous3
Marvelous3's Avatar
I can replace the timing belt with a razor blade in 15 minutes. Hood open to hood shut.
So here’s the thing and why I semi jokingly said $1500. Does the ac work? Probably not. Does it need new bushings? Especially the rear trailing arm bushing? Probably. Has it had the blower motor replaced? When’s the last time it had a fuel pump? Or overdrive solenoid/relay? How old are accessory belts and did they change the bushings the last time they did the belts? Speaking of bushings, when’s the last time it got motor mounts? That drivers side mount is definitely broken or about to if it’s older than six months.
These are all bull**** things that while seemingly cheap end up being giant pain in the asses to do yourself. So it might look nice on the outside but until they’ve done some or all of this stuff it’s a $1500 **** box. The keystone is just so we don’t get thirsty listening to the seller talk about how great the car he’s selling is. If it’s so great why sell it? Oh…it’s got one or more of the problems above and he doesn’t/can’t/won’t fix them.
Edit://
Ntsb national average is about 15k miles per year. I drive my red wagon way less than that. So let’s say guy did drive his 240 15k on average. That t belt 40k miles ago was two and a half years ago. If he’s driving that car closer to 10k miles a year the t belt is four years old. It’s definitely nothing close to brand new.
Old 12-21-2021, 10:41 PM   #17
Change it at 40K to be on the safe side anyway.
Old 12-22-2021, 12:02 AM   #18
sheepbleat
+1 to all this. Being a one-owner car doesn't make it not a 30-year-old car.
I get that we can't just throw rocks and hit $500 240s anymore, but $3k won't feel like a bargain if you have to pay a mechanic to do any of this.
Making a respectful offer to your friend is definitely the way to go, but don't be afraid to politely walk away if he won't budge and everything rubber on the car is a ghost of ****boxes past.
Time makes fools of us all, especially belts and bushings.
Greg
My Feedback Thread
Old 12-22-2021, 10:27 AM   #19
lyonsfin
If its rust free and drives safely, I think $2500-$3500 all day. I'd buy it!
Old 12-22-2021, 11:03 AM   #20
white855T
Unless its a time capsule, it will have to be gone through. Pictures would help!
Old 12-22-2021, 02:12 PM   #21
VolvoScout
VolvoScout's Avatar
Syntax Error
Huh?
Does not compute.
Old 12-22-2021, 02:23 PM   #22
Mr. V
Mr. V's Avatar
Originally Posted by VolvoScout View Post
Syntax Error
Really?
How so?
The OP said the car apparently has 22K miles on it, but the belt was changed 40K ago.
Quite contradictory claims.
Normally I'd say "the odo has flipped over" but on these old Volvos it goes up to 999,999 before flipping, so if the odo shows 22K how could the belt have been changed 40K ago?
Unless the odo was replaced / tinkered with.
Something isn't kosher here.
Old 12-22-2021, 02:31 PM   #23
VolvoScout
VolvoScout's Avatar
I was agreeing with you
Really?
How so?
Old 12-22-2021, 04:38 PM   #24
Old and boxy but good.
It means the odometer has been broken since 22k miles and it's been approx 40k miles at a guess since the timing belt was changed.
Old 12-22-2021, 08:09 PM   #25
sheepbleat
Damn. 22k is a short life for an odometer, even by our standards.
