Old 10-22-2010, 06:09 PM   #1
crazyoctopus
Default YoshiFab Valve Relief Tool How to
Start with the block, all dirty and grimy.
then clean the pistons off to insure a great seat of the drill and why not?
Then make sure that you have everything needed
After setting the pistons at their highest and lowest points tape off the top of the block with your favorite tape; this eases cleanup and protects the oil and coolant holes from collecting unwanted metal shavings
Cut some slits so that you can bolt in the tool and tighten down the bolts
Check to make sure that the proper depth is met
Tighten your favorite drill to the valve relief drill
The key to drilling the reliefs is that you go slowly (low rpm) and let the drill do all the work; i.e. do not put much, or any, downward force on the drill.
http://www.youtube.com/watch?v=dp9Lxrd7dtg&hd=1
Rinse and repeat that on all of the bits. After completion remove the tool and look at the damage you have done
Put just the bolts back in to make sure that none of the shavings get into them, and brush them off
Remove the tape to reveal your relived piston (eh eh; get it, get it? it is relieved because it wont get slapped by a valve! bah!)
Now re-tape the now exposed cylinder to protect it from the subsequent drilling. After that has been completed do the exact same process, minus the depth check, on all of the cylinders. Once completed it should look just like this.
Now pour your self a stiff cocktail, beer, or non-alcoholic beverage and move onto something else.
<3 from the CrazyOctopus
crazyoctopi.blogspot.com
flickr.com/crazyoctopus
crazyoctopus is offline   Reply With Quote
Old 10-22-2010, 06:39 PM   #2
volvorsport
looks oem that .
do they sell this kit or what ?
muhahhahahhhahhaha !!!!!!!!!!!!!!!!!
volvorsport is offline   Reply With Quote
Old 10-22-2010, 07:06 PM   #3
740atl
Gear acquisition syndrome
740atl's Avatar
That's a really ingenious kit, of which I shall want to rent.
Question tho... shouldn't you really use a hg underneath the partial head? Even tho the hg is only 1mm, it will change the angle of "impact" slightly with the piston, won't it?
Great job and great idea guys!
Old 10-22-2010, 07:35 PM   #4
sdturbo
sdturbo's Avatar
The cutters are larger than the valves themselves. Shouldn't be a problem.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 10-22-2010, 07:49 PM   #5
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
I like this.....
962j 815/692@27psi
THIS IS FORSALE V
Old 10-24-2010, 08:15 PM   #6
badvlvo
Bad for Babies
badvlvo's Avatar
This will be used for my build in the near future.
Died at age 35
1988 244
Old 10-24-2010, 10:20 PM   #7
Gralin
How much does the "system" rent for and how long is the list waiting for it?
Gralin is offline   Reply With Quote
Old 10-24-2010, 11:57 PM   #8
sdturbo
sdturbo's Avatar
Rent it HERE
Old 10-25-2010, 09:46 AM   #9
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
that's fantastic.
Megasquirt Tuning!
Old 10-25-2010, 06:48 PM   #10
fast242
I had a Jewish wedding
fast242's Avatar
Thanks Josh, Dave Barton and the rest of the people who helped make this happen. The tool is a heavily cut up 16v head and the cutters are the custom part and the real expense in making this tool. One part that seems missing is the information of the crank locking tool. You can see it in a few pictures. It is the two bolts with a square bar over the fully recessed piston next to the cutter tool. Thanks for the writeup on it.
PJ
84 242Ti 16V build up
83 245Ti daily driver lots of common mods
1992 745Ti stock
16V Block mounted LH2.2 distributors for 16V conversions on 240's, now for sale, just click this link
Pics Of the 242 and other stuff
http://www.pbase.com/fast242
fast242 is offline   Reply With Quote
Old 10-25-2010, 06:56 PM   #11
Tamnakz
Tamnakz's Avatar
Freaking sweet.
Ya'll are pimps!
EMT's, Police, nurses. Apparently the State trooper got on the horn and told everyone. They didn't know it was a volvo.
'76 244 *sold*
'86 244 *crushed*
'87 745ti N/A pistons M46 *parked*
'88 745 -work status-
'89 744 *sold*
'91 944 16v -dd-
'03 V70 -travel bi***-
Tamnakz is offline   Reply With Quote
Old 10-25-2010, 10:07 PM   #12
fast242
fast242's Avatar
Originally Posted by Tamnakz View Post
Freaking sweet.
Ya'll are pimps!
Beats killing people by only a little.
PJ
Old 10-25-2010, 10:57 PM   #13
crazyoctopus
just barely.
Old 10-26-2010, 11:38 AM   #14
SteveMD
Membro
SteveMD's Avatar
Noice, may do this since I have the prerequisite 16 thumbtacks head.
Old 10-26-2010, 12:27 PM   #15
B-lennium
the edge's look real sharp, don't you get pre ignition by that?
Volvo 164e B30e, Megasquirt MSII extra
B-lennium is offline   Reply With Quote
Old 10-26-2010, 01:44 PM   #16
sdturbo
sdturbo's Avatar
Nope. You could always ease the egde with some sand paper if you are worried about it.
Old 10-26-2010, 01:55 PM   #17
i drift volvos
cracker
dude....thats bad ass!
1986 Volvo 245 v8 drift project
i drift volvos is offline   Reply With Quote
Old 10-26-2010, 02:52 PM   #18
Cosmic
Guest
Excellent.
Old 05-27-2011, 02:57 AM   #19
fast242
fast242's Avatar
Originally Posted by Cosmic View Post
Excellent.
We aim to please.
PJ
Old 05-27-2011, 10:01 AM   #20
turbojose
I just used it.... worked great. total job took about an hour. awesome tool
turbojose is offline   Reply With Quote
Old 06-01-2011, 03:29 PM   #21
dbarton
Dejected by Volvo Corp.
dbarton's Avatar
Can someone please share the clearance depth you're using for stock cams. It's not mentioned in this thread.
Dave B
'84 242ti, fourth owner, mine since 2003. Garaged since new. Old-school rounds because. B21FT, EMS: SDS EFI & IGN, TD04HL-15G turbo, T5Z trans with 0.73 OD, 3.91 diff, unmodified G80.
Volvo's Ambivalence of Volvo Enthusiast Community: prancingmoose.com/#novolvo
Old 06-01-2011, 03:37 PM   #22
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
Don't think it matters, as far as I know all this does is make reliefs so that when the piston is at TDC it doesn't hit the valves, nothing more.
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 06-01-2011, 03:41 PM   #23
Dave B
It's stamped on the tool. .160" for the intake and .135" for the exhaust.
Old 06-01-2011, 04:47 PM   #24
The Aspirator
It's a girl!
The Aspirator's Avatar
Excellent tool, great job to everyone involved!
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 06-01-2011, 07:02 PM   #25
dbarton
dbarton's Avatar
Awesome, thanks. My B230 motor now has valve reliefs.
