Old 03-24-2011, 02:20 PM   #1
SteveMD
Membro
SteveMD's Avatar
Default The hardest part of a +T must be....
..... cutting the goddamn 1/2" NPT threads with the NA block in the car. Yes, I am turning the tap a smidge, backing off, turning again, and even taking out to clean from time to time. Tap is lubed. If I was doing this again, I would cut 1/2 NON-NPT straight threads as I am guessing that would require less muscle and time. [/rant off]
Old 03-24-2011, 02:46 PM   #2
Aurelius
word
Aurelius's Avatar
+1!!!
Aurelius is offline   Reply With Quote
Old 03-24-2011, 02:47 PM   #3
m46destroyer
Just that good
m46destroyer's Avatar
Weld bung on pan, done.
82 244GLT 250k
1979 Impala
90 E350 4x4 D60's 35"'s Turbo7.3IDI E4OD
m46destroyer is offline   Reply With Quote
Old 03-24-2011, 02:48 PM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
or just quit bitching and use better tools?
Megasquirt Tuning!
Old 03-24-2011, 03:12 PM   #5
gross polluter
They see me trollin'
gross polluter's Avatar
This.
1981 Piper Cherokee Archer II | Garmin GTN 750 | Ly-Con O-360
Old 03-24-2011, 03:22 PM   #6
But then the bung points downward...
Old 03-24-2011, 03:38 PM   #7
gross polluter
Only if you weld it to the bottom of the pan.
Old 03-24-2011, 03:52 PM   #8
SteveMD
Membro
SteveMD's Avatar
Like what? The tap is a new Irwin/Hanson, made in USA AFAIK. I guess I need to eat more spinach.
Old 03-24-2011, 03:55 PM   #9
r55nls2002
The $H!T Wagon Express
r55nls2002's Avatar
Are you using anti-seize as lube?
00 Toyota Echo DD
87 240 wagon
Now Improved: EZK, very small snail, and the Jerd Brace
r55nls2002 is offline   Reply With Quote
Old 03-24-2011, 04:02 PM   #10
poulrais
poulrais's Avatar
I'm about to +T my 240 and from what I read this part of the mod seems to be a pita... I'm going to pack up on elbow grease for sure!!
1990, Volvo 740 16v +T
Old 03-24-2011, 04:03 PM   #11
740atl
Gear acquisition syndrome
740atl's Avatar
We did three in one weekend. Hardest part was wiping the smile off the owner's faces.
Old 03-24-2011, 05:03 PM   #12
Aurelius
word
Aurelius's Avatar
lol linuxman51!!
Old 03-24-2011, 08:24 PM   #13
varg
kludgemeister
varg's Avatar
Eff that. Get a spare oil pan, weld a bung in, swap out oil pans. Done.
'85 244DL B21FT swap (gone ), ->Project thread
'91 E30 318is, M20 swapped, turbocharged. project in progress.
Kawasaki ZRX1200R
varg is offline   Reply With Quote
Old 03-25-2011, 01:31 AM   #14
Hagar17
Hagar17's Avatar
My +t was the hardest but that was my fault...
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 03-25-2011, 08:25 AM   #15
SteveMD
Membro
SteveMD's Avatar
Nope, just grease to catch chips.
Old 03-25-2011, 08:59 AM   #16
rogerthechorister
Default Swap sump?
Dunno about B230s, but swapping the sump involves lifting the engine on the B234F
rogerthechorister is offline   Reply With Quote
Old 03-25-2011, 10:39 AM   #17
mikep
The MP
mikep's Avatar
PM sent.
I will be in the district Saturday.
It was a Datsun, it was more likely rust in something ...
Originally Posted by propav8r View Post
Ain't my couch.
F*ck that couch.
Old 03-25-2011, 12:42 PM   #18
MrBill
fige=500Dollar Mistake
MrBill's Avatar
Is the 1990 LH 3.1 turd getting turbo'd?
Someone say crazy rays?
Old 03-25-2011, 12:51 PM   #19
If it is LH 3.1 I seriously want to have a chat with ya.
Old 03-25-2011, 03:38 PM   #20
towerymt
the real Towery
towerymt's Avatar
I DD a '92 M47 that was convered to 2.4 and to turbo before I got it. Most of the info is out there.
Old 03-25-2011, 04:24 PM   #21
I know about the 2.4 swap, and it isn't hard. Got wiring diagrams and hardware for both 3.1 and 2.4 T, which is only slightly different than 240 2.4.
I just want to see if anybody else ventures into adapting 3.1 to forced induction use before I do...
Old 03-25-2011, 05:30 PM   #22
SteveMD
Membro
SteveMD's Avatar
+Turd, yes
Old 03-25-2011, 05:32 PM   #23
SteveMD
Membro
SteveMD's Avatar
Will do. I heard someone here, maybe previous owner of Towery's DD ran 3.1 with 5 psi. no issues. Also vaguely recall someone else doing about the same. I may try 5 psi while keeping eye on knock sensor and wideband.
Old 03-25-2011, 05:42 PM   #24
Good deal. Lucky from IPD tells me that at least LH 3.2 (+T'd 1993 850) runs boost without any issues until 5 PSI or so, from which he told me the system started running pig rich. He recommended putting a piggyback on in order to compensate for MAF readings or something like that.
In any case, I'm intrigued: the real TPS and more advanced MAF should work nicely.
Old 03-25-2011, 07:00 PM   #25
FunkyStankyChicken
Rad Panda
FunkyStankyChicken's Avatar
I seem to recall it taking about 20 mins to thread the hole. Cast iron is soft as all getout.
‘02 V70xc
‘96 F350
‘93 525it
‘88 325is
‘84 533i
‘79 242
FunkyStankyChicken is offline   Reply With Quote
