Old 03-29-2011, 09:47 AM   #1
SteveMD
Membro
SteveMD's Avatar
Default +t braided oil supply line length ?
Assuming I am successful in unplugging the oil gallery on the front of my block and fitting a 90 degree 1/4NPT-AN4 adapter, about how long a line will I need to reach the 15g oil inlet?
I would like to order stuffs from http://www.pegasusautoracing.com/home.asp todays
2013 XC60 T6
2006 330i
Originally Posted by gottarollwithit View Post
I'm sure I can manage to get by w/o reverse, but it is a nice amenity.
Old 03-29-2011, 12:13 PM   #2
The Aspirator
It's a girl!
The Aspirator's Avatar
I made all my at 21" of HOSE, so fitting to fitting would be a longer measurement. 24" works great too.
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 03-29-2011, 12:48 PM   #3
JW240
All idiot, no savant
That length works good, leaves enough clearance and space to clear the many doohickeys surrounding the engine.
pic:
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a many months)
dd: 940 | 1992 | B230FB | Polaris | some mods
Old 03-29-2011, 12:53 PM   #4
SteveMD
Membro
SteveMD's Avatar
Thanks, guys. AN4, right?
BTW, what ID size hose do I need to connect the Mitsui coolant hard lines? I can order that from Pegasus as well.
Old 03-29-2011, 01:49 PM   #5
leslie_s
pic:
are those seats in the pic for sale by any chance......?
i drive a 2008 Jeep Wrangler
Originally Posted by cancer man View Post
On May 21st 2011, the official majority language will be Hispanic in the great U.S.A. Adios Gringo.
leslie_s is offline   Reply With Quote
Old 03-29-2011, 02:07 PM   #6
JW240
M12x1.5, same as feed. The feed I have is AN3 iirc.
They are back in my car now, besides, shipping them over the pond wouldn't be worth it
Old 03-29-2011, 03:34 PM   #7
kahluaTDI
kahluaTDI's Avatar
-3 would be better as you won't need to run any restrictions. Also, run it directly to the turbo instead of around it like in the picture. That's just a waste of line.
.Signature.
kahluaTDI is offline   Reply With Quote
Old 03-29-2011, 03:36 PM   #8
SteveMD
Membro
SteveMD's Avatar
Thanks, I wasn't sure if a 15g likes a -4 or -3. By directly to the turbo, you mean run it up by the head then to turbo?
Old 03-29-2011, 03:44 PM   #9
The Aspirator
It's a girl!
-4 works fine, no need for restrictors unless you're running a fancy ball bearing turbo. Also running it around the side like JW there keeps it away from the glowing hot manifold. Just cuz it's stainless steel doesn't mean that the ptfe inner liner won't melt. And at 21" it's not nearly as long as his hose, fits much snugger to the outside of the turbo.
Old 03-29-2011, 04:11 PM   #10
JW240
agreed 100% on all accounts. For those who don't know, my line was supplied by John.
Old 03-29-2011, 04:18 PM   #11
turtle
Gun loving Pitbull owner
turtle's Avatar
20" - 24" is plenty.......any more or less will result in
1991 940 TURBO WAGON
IPD sways front and rear,polys,adjustable panhard,new kyb struts and shocks,drop springs,ported 90+,T3 55 trim,COSWORTH wastegate,12psi,TLAO 3" downpipe,TLAO chips,K&N cone,heatshield and lots of BASS
I may not be "all that", but I am some if it
Things i want....PM if you want to sell
965 gate stuff, SE kit(front and rear bumper and side skirts)and 965 taillights
BrickSpeed....faster than TB
turtle is offline   Reply With Quote
Old 03-29-2011, 05:09 PM   #12
towerymt
the real Towery
towerymt's Avatar
22-24" with straight fittings on both ends. Straight adapter fitting threaded into the turbo. You'll be able to go on the "cold" side of the compressor housing away from the exh manifold (as shown above). On the autoX car I had to go between the comp housing and the exh. manifold because the line was shorter and because the T04 comp housing is huge (it fit under/around the T3).
Use mapp gas or similar, careful bit of heating/cooling on the plug/block, and then clean out the hole, tap in an allen wrench, tap with a hammer, should come right out. I did one a couple weeks ago, was shocked how easy it was with the right tools.
If you use a 90 degree fitting into the block, stick a screw driver into the timing belt cover bolt hole and break a chunk off the cover. Or remove the cover. I just broke it since both I've done were already cracked. Then I put the piece back on, and put the bolt back in once the fitting is in place.
-3AN line with -4AN fittings works fine (premade line, crimped ends). I've also used -4 line with -4 fittings on a custom line mikeP had made for me at the machine shop, but that was a bit more expensive. But nice that I can change the fittings as needed.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 03-29-2011, 07:53 PM   #13
SteveMD
Membro
SteveMD's Avatar
Old 03-29-2011, 08:27 PM   #14
Xovaan
drunk, alone at applebees
Xovaan's Avatar
Don't suppose anybody would wanna make a braided oil line kit for me, would they?
15g + b230FT with a standard 90+ manifold in a Volvo 240? I could do it myself but I'm really strapped on time :(
1993 245 + B230FT
2007 Bandit 1250
Xovaan is offline   Reply With Quote
Old 03-29-2011, 08:50 PM   #15
turtle
turtle's Avatar
order one from ATP or some place like that
Old 03-30-2011, 12:48 AM   #16
The Aspirator
It's a girl!
Ohh haha, even I forgot that. I thought those fittings looked familiar. Well then ignore my previous comment, that line pictures uses exactly 21" of hose.
Shoulda told me that before I sent off the shifter knob! Btw you get it yet?
Old 03-30-2011, 05:00 AM   #17
Xovaan
Xovaan's Avatar
Hahaha oh yeah! I forgot you can make those too.
Hell yes I got it! Looks rad and feels great! (ZVOLV likes it too!) I like the rubber of the original shifter knob but the shape of the new one just feels right.
Old 03-30-2011, 11:54 AM   #18
kahluaTDI
kahluaTDI's Avatar
Making the lines is actually pretty simple and cost effective. Don't be afraid to make your own lines.
