Old 04-09-2011, 02:48 PM   #1
Roger-Dee
is DeeWorks.ca
Roger-Dee's Avatar
Default A quick one
Last year I redid most of my wiring, and I put all these wire in the same loom;
- Ebc
- Spark A & B (running ls2 coil)
- Tps wire
- Iat wire
I was wondering if I should route some of them away from the other ?
This year I'll be using the second injector channel so 2 wire will be added in the loom. I guess what I really want to know is am I looking for noise problem ?
94 944T - 16v turbo - 12,14@122
Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107
www.deeworks.ca
Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me!
Roger-Dee is offline   Reply With Quote
Old 04-09-2011, 03:03 PM   #2
The Aspirator
It's a girl!
The Aspirator's Avatar
Are the spark wires individually shielded? Cause they might wreak havoc with your tps or iat signal, causing accel enrich to come on. I used 2 or 3 core shielded wire for all my wires, so each output/input was individually shielded and I haven't really had problems with that. (except for the touch probe on my cnc mill, same wire but falsely tripping every few seconds!).
I'd keep rpm in and spark out wires very shielded and away from each other, everything else isn't such a big deal I don't think.
John
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 04-09-2011, 03:17 PM   #3
gross polluter
They see me trollin'
gross polluter's Avatar
His spark outputs are logic level. 5v@20ma won't cause harm.
1981 Piper Cherokee Archer II | Garmin GTN 750 | Ly-Con O-360
