Old 05-13-2011, 01:26 PM   #1
mrnabisco
mrnabisco's Avatar
Default Chrome Valve Cover Nuts
Anybody ever source out chrome valve cover nuts?
I'm putting a freshly ported/polished head on my NA B230 and thought I'd give it just a touch of bling...
mrnabisco is offline   Reply With Quote
Old 05-13-2011, 01:27 PM   #2
Tfest
Hipsters ruin everything™
Tfest's Avatar
they're just little 10mm acorn nuts, iirc, and you can find them at just about any hardware store.
Lifted 240 Build Pages
TB Build Thread
Instagram Page
Tfest is offline   Reply With Quote
Old 05-13-2011, 01:46 PM   #3
arnoroth661
arnoroth661's Avatar
http://www.ipdusa.com/version.asp?st...=465&V_ID=6999
arnoroth661 is offline   Reply With Quote
Old 05-13-2011, 01:55 PM   #4
mrnabisco
mrnabisco's Avatar
Too easy. Silly me...
Old 05-13-2011, 02:02 PM   #5
The Aspirator
It's a girl!
The Aspirator's Avatar
6mm threads, use a 10mm socket. They'll be called M6 acorn nuts. Use washers with them. I've been using stainless steel ones for years, they really bling up the valve cover. A GOOD hardware store should have them (ie, not home depot, although maybe).
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 05-13-2011, 02:05 PM   #6
- Stock PSI Or Bust -
I just bought a bag of stainless from Mc Master Carr.
They're good for the license plates too.
how psi stock cna sprout?
Old 05-13-2011, 02:21 PM   #7
Tfest
Tfest's Avatar
thanks for the clarification, i couldn't remember.
this is how they look on my motor
Old 05-13-2011, 02:23 PM   #8
smokeyfan1000
Guest
The OEM Volvo cam cover nuts aren't actually chrome. If you want show chrome nuts, try a Japanese/ Custom Motorcycle Shop. Or maybe even an online motorcycle supplier like JP Cycles. Jap bikes have lots of nut in this same size I'm sure.. And there are chrome acorn nut dress up kits for them, and most good shops have a drawer full of individually available ones too.
Polished SS nuts will last & look good much longer BTW
Old 05-13-2011, 03:21 PM   #9
The Aspirator
It's a girl!
Even unpolished, the SS ones looks really shiny and nice forever. Not nearly as "chrome" as chrome ones would, but plenty good enough for these old rust buckets.
Old 05-13-2011, 03:22 PM   #10
Mueller
Mueller's Avatar
Best Performance thread ever
Old 05-13-2011, 06:08 PM   #11
mrnabisco
mrnabisco's Avatar
Chrome nuts as a performance thread... Yeah, all show no go but I figured I'd get a better response here then on the maintenance thread.
Thanks for the info. I like the SS look.
Old 05-13-2011, 06:10 PM   #12
The Aspirator
It's a girl!
Old 05-13-2011, 07:55 PM   #13
smokeyfan1000
Guest
I've been buying 14 of the OEM Volvo nuts once every year or so. 10 for cam Cover, 4 for license plate.
AAMOF I have a bag of them here on my computer desk...They come in a 10 pack... p/n 968458 Qty 10.
Old 05-13-2011, 08:08 PM   #14
Poik
Backwards Turbo
Poik's Avatar
Honestly, it scares me how much money you must have tied up in your car.
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 05-13-2011, 08:11 PM   #15
scotti
Master Lurker
scotti's Avatar
You change your nuts every year or so?
Wagon power 93 945t 18psi 320,xxx
Zipties= Higher Power
scotti is offline   Reply With Quote
Old 05-13-2011, 08:16 PM   #16
smokeyfan1000
Guest
No...I change the cam cover nuts every year or so.
Old 05-13-2011, 09:37 PM   #17
paulcurran
Default license nuts
Be sure to use washers if you use oe license nuts as the threads are a little shorter & the acorn nut will jam on the stud before tightening the cover. Ask how I know that.
paulcurran is offline   Reply With Quote
Old 05-13-2011, 09:41 PM   #18
Hey Mueller, your ish running yet?
Old 05-13-2011, 09:50 PM   #19
smokeyfan1000
Guest
I've never had to use washers with OEM Volvo cam cover nuts. They also fit the License Plate studs as Redwood Chair stated. Why I use them. They stay shiny for a year or two.
Old 05-13-2011, 10:13 PM   #20
The Aspirator
It's a girl!
And stainless stays shiny forever....
Washers are a good idea but not always required, you see a lot of older 240's where the acorn tops have popped off because someone didn't use washers, or cranked them down too tight squishing the gasket more than necessary.
Old 05-13-2011, 10:26 PM   #21
smokeyfan1000
Guest
Might be caused by the cam cover studs not being fully seated?
Old 05-14-2011, 12:49 AM   #22
boosted12a
weapon of mass detonation
boosted12a's Avatar
take a ratchet and 10mm socket, pay 1$ to get into pick and pull. go to the nearest hondas and accuras. most only have 2 chrome acorn nuts but youll be able to find all you need. stick em in your pocket and there you go. if you have a problem with that, show the cashere and they will ptobbaly laugh at you for offering to pay for 10 nuts
91 940 SE, 119K, GOLD
03 540i M sport 6 gears of go! 200k, White
05 S80 2.5T, RED
09 XC70 3.2L, BLUE
10 335xi, (fun has a price), black
17 expedition El, (short bus), black
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
