Old 06-15-2021, 09:18 PM   #1
DavePolyakov
Default Replaced 740 seats, seatbelt is stuck?
As the title says. Put in newer seats and the passenger side seatbelt is locked after I reinstalled the seat belt onto the new seat. There's no issue with the system under the B pillar, I already removed it to check and everything is fine. The issue is in the part that bolts to the seat. How can I unlock it? Don't want to kill my passengers I need to fix it asap. I feel like if I start taking it apart I'm going to mess it up for sure.
DavePolyakov is offline   Reply With Quote
Old 06-15-2021, 11:30 PM   #2
Mr. V
Mr. V's Avatar
This link might get you started...
https://www.swedespeed.com/threads/s...-stuck.230027/
Old 06-16-2021, 05:35 AM   #3
dalek
Benchracer Tribe
dalek's Avatar
Try grabbing the part that goes on the seat just below where the belt comes off and rotate it until it is about vertical. At least that is what solves that in my 740
Feedback!
Old 06-19-2021, 11:48 PM   #4
lummert
lummert's Avatar
The retractor has to level.
Old 06-21-2021, 06:40 PM   #5
DavePolyakov
Can someone elaborate a little bit more? I'm still unsure what you guys are proposing I try to get the seatbelt to work.
Old 06-21-2021, 08:51 PM   #6
You gotta have it at the correct angle to unlock. It can be tough
I would unbolt it and try to hold it at different angles and see if you can get it to release.
