Old 07-29-2021, 10:22 PM   #1
autoloclys
Default uneven running, fuel pressure issue?
having an annoying issue but so far it hasnt left me stranded.
In normal driving on the road, the engine in my '92 240 will occasionally stumble a little, its most noticeable between 1500-2000 rpm. Idle is smooth and above 2000 rpm the stumble is either not there or not noticeable
both fuel pumps are new since i bought the car and seem to be running (i can hear them when i check), Fuel pressure regulator also seems fine, no fuel in the vacuum line. and all the fuel lines between the tank and the engine have been replaced, though the return line is hose and not hard pipe
is it possible the intank or under car fuel pumps are running but not supplying sufficient pressure for certain conditions? neither one is a volvo part, but i would expect them to work or not work, rather than lose pressure slowly or intermittently.
or am i totally up the wrong tree with the fuel system?
autoloclys is offline   Reply With Quote
Old 07-29-2021, 10:47 PM   #2
James M
Bored member
James M's Avatar
James M is online now   Reply With Quote
Old 07-30-2021, 02:31 AM   #3
mattd1205
mattd1205's Avatar
I’d check for codes first if you haven’t already. If you suspect a fuel pressure issue, throw the autozone rental fuel pressure gauge on there. It doesn’t come with the fittings you need but you can cut up a fuel rail and part of the fuel line from a junk Volvo at the junkyard to make an adapter that will plumb into the tee fitting that comes with the gauge kit.
mattd1205 is offline   Reply With Quote
Old 07-30-2021, 02:39 AM   #4
Otto Mattik
board member
Otto Mattik's Avatar
a) injector leak ?
b) fuel pump relay ? (what brand)
c) AMM resistance check out ?
Old 07-31-2021, 07:15 AM   #5
Janspeed
d) throttle body axel wear? (causing intermittent vacume leak)
