![]() I have a 1992 745 Turbo. I went to NAPA to find an all metal replacement. The employee helping me asked if vacuum oped or shut the valve. I do not know. Do you know? Thanks.
1992 745 TI+ anti slip differential, 1983 242 DL, 1990 780 Bertone, 1983 242 Group A X 2 |
Stage 1
![]() Not sure how a vaccine would work on a heater valve, I think there are little to no studies out there yet.
What I am pretty sure about is that the vacuum shuts the valve, so they are open by default. Motorcraft YG136 is the valve people have used from what I've read.
#3 | |
![]() Quote:
Click below: Buyer/Seller Feedback My Volvo parts for sale on eBay Volvo parts for sale on forum - Post are regularly updated |
#4 |
![]() Yes the YG136 is great. That valve is the first part on the stage zero list for any new to me 7/9 Volvo
#5 |
![]() ![]() Autocorrected to vaccine instead of vacuum? I don't 7/9, so this is the only way I'm able to help.
Feedback - https://forums.turbobricks.com/showt...ht=volvowagoon 1986 Buick Grand National - Restored to stock™ 2002 Camaro V6 T5 +T - The trashy car that's fun to drive 2010 C30 T5 - The boring but trusty daily - 199k 1989 245 DL - The boring but not trusty daily - 233k IG: @v6buick |
#6 |
![]() The valve is normally wide open.
The valve closes under vacuum, usually only when the system is set to "maximum cooling". This simply blocks coolant flow through the heater core, and (some say) disrupts the flow through the rear cylinders, possibly making them run too hot. Common options seem to be: The stock half-metal style that tends to break off one nipple: The all-plastic version: ![]() The all-plastic "flying saucer style with no external shaft to leak: ![]() The mentioned YG136 version, that looks half-plastic, but may have an all-metal version: The all-matal AC Delco 15-5320: ![]() And of course, the GM 660-1357 bypass style, that "short-circuits" the flow and sends it back, instead of just cutting it off: http://turbobricks.com/forums/showthread.php?t=246617 ![]()
1990 740GL 534,000 km so far... Last edited by MasterBlaster; 08-09-2021 at 05:11 PM.. |
#7 |
![]() Delco 15-5320 was mentioned before as good to use: http://turbobricks.com/forums/showthread.php?t=242812
#8 | |
board member
![]() Quote:
Almost looks like the one on my Ranger ![]()
Desperate need of elf assistant for interior work - Cash/Beer option $ Feedback thread: http://forums.turbobricks.com/showthread.php?t=323689 |
#9 |
![]() GM 660-1357 bypass style seems a way smarter solution.
#10 |
Våga Vägra 8V
![]() But where to route the bypass.. No pnp h
Right here ![]() |
