Old 08-12-2021, 11:45 PM   #1
Brick-hi
Brick-hi's Avatar
Question 240 hood wont open
Hello once again. I've got a 92 240 wagon. I started to close the hood and the hinges bent. The hood doesn't look like it's bent but after I closed it only the first latch releases. I took the grill out when I had it open...... so I have some access but I cant get the other pin with the spring around it to release.
Does anyone know how to get it to release?
Edward
Brick-hi is offline   Reply With Quote
Old 08-13-2021, 10:09 AM   #2
Brick-hi
Brick-hi's Avatar
Thumbs down Hood latch pin
After researching the Bentley's manual I see that what is not releasing is called the "hood latch pin". But it doesn't tell me how to get it to release.
Old 08-13-2021, 10:40 AM   #3
- Stock PSI Or Bust -
Pry it over with a big screwdriver while someone pulls the release lever.
how psi stock cna sprout?
Old 08-13-2021, 11:32 AM   #4
nel621
If all else fails and you can get hood open just a little, you can always take a 10 mm wrench and remove the bolts holding the lower section of the latch.
Old 08-14-2021, 03:20 AM   #5
Otto Mattik
board member
Otto Mattik's Avatar
In a situation like this, what has worked for me is:
a) push down on the hood
b) after nose of hood is down have helper pull and hold release lever
c) then pull up on hood
The only other option I can see is either what RWC or Nel suggested
Old 08-14-2021, 08:24 AM   #6
alschnertz
Enough already!
alschnertz's Avatar
After you get it open, it'd be a good idea to oil the hinge points.
Old 08-14-2021, 09:08 AM   #7
nel621
Be thankful you removed the grille first.
Old 08-14-2021, 02:42 PM   #8
Mr. V
Mr. V's Avatar
Tips for 740:
http://www.swedishbricks.net/700900F...k_Hood_Release
Old 08-14-2021, 09:40 PM   #9
Radtap
Radtap's Avatar
On mine I was able to reach up behind the bumper with a long flat nose and pry the steel bar that latches around the pin. Once it was open I swapped it with a new one from a later year and adjusted it.
Radtap is offline   Reply With Quote
Old 08-16-2021, 11:02 AM   #10
Dvroofer
Dvroofer's Avatar
Just be sure when you fix it, that it is aligned correctly and double check it locks correctly…. I learned the hard way [IMG][/IMG]
Dvroofer is offline   Reply With Quote
