Old 09-01-2021, 03:26 PM   #1
morsing
Default Over-tightening stretch bolt
Hi,
Fitting the crankshaft damper center bolt, I remembered the stage 2 angle wrong and did 180 degrees instead of 90! How bad is this? I've backed it out to about 120 degrees now, but should I get a new bolt?
Thanks
Henrik Morsing
'89 Volvo 240GLT B230E/AW70
'14 Volvo V70 SE D4/M66 FWD
'70 Chevrolet Chevelle Malibu 350/TH350
morsing is offline   Reply With Quote
Old 09-02-2021, 04:46 AM   #2
Janspeed
I'd say if nothing snapped let it be. It's bloody tight as it is, right?
But if you ever have to take the damper off again, then make sure to use a new bolt.
Old 09-02-2021, 03:13 PM   #3
Old and boxy but good.
If I recall correctly the crank bolt gets 60 degrees of angle torque. So you got that very tight on there. If it didn't break I'd second Jan's suggestion to leave it be. Just have a long breaker bar or impact for removal when you do your next timing belt. Plus a new bolt.
Old 09-03-2021, 04:10 AM   #4
morsing
Hi,
According to VIDA it's 110Nm + 90degrees.
For peace of mind, I picked up another bolt. I think it would have nagged me forever, if I hadn't.
Thanks
Old 09-04-2021, 01:44 AM   #5
MasterBlaster
MasterBlaster's Avatar
Okay, the S/V/C prefix points at your 2014 V70 SE (UK specs?).
What's the "D4" part?
Maybe it uses the same bolt as your (I assume presumed by others) 240, maybe not.
The specs could be wildly different, depending on the engine (sorry... motor?) fitted.
1990 740GL
534,000 km so far...
Old 09-04-2021, 04:06 AM   #6
morsing
D4 is the engine.
https://en.wikipedia.org/wiki/Volvo_...ecture#D4204T5
Definitely not the same bolt as a 240.
Old 09-04-2021, 12:05 PM   #7
The well respected clean burning Volvo diesel we never got.
Old 09-04-2021, 12:08 PM   #8
morsing
Can't figure out if that's sarcastic or not, but 110 000 miles and no sign of smoke so far.
Old 09-04-2021, 12:12 PM   #9
Yeah, inflection is hard to convey. I meant that sarcastic as you suspected. I always thought it was kind of dumb of Volvo not to offer those engines here in a large market. The diesel they did sell here wasn't made by them and then when they do make their own diesel they don't sell it here.
