![]() Just last year I purchased a 1968 Volvo 142s to restore and to be my first car. The gentleman who sold it to me assured me that it only needed brakes and some cosmetics. I believed him probably too soon. Throughout this time I have had to completely rebuild the brake system, the carburetors were shot, the ignition system made no spark at all ect. Continuing on with the rebuild with good faith that it would run and drive well someday. The time came around two months ago. Before and during the first drive I found many more problems. Before the drive, I found that the rear differential was bone dry and the transmission was low. I topped them off and on the drive it drove pretty well. I drove it about three times between now and then. Tonight, on one of its rare night drives, I did my normal procedure of checking all the fluids (except the diff fluid) before heading out. Everything was in order. After about a 20 min round trip, i got home and tried to put the car into park... it seems that there's no park only neutral #2. Next I tried to put into reverse to try to re-park as it had rolled down the driveway. reverse seemed to be neutral #3. Scared that something was up, I pulled the car into the driveway and just used the emergency brake as park. I then checked the transmission fluid and it was bone dry.
![]() Wow this is quite a contrast from the previous thread I posted ![]()
volvvovlovlvovovlovlvovlvovlvovlvovlvooovlovovovoo vl Last edited by 1968 volvo; 10-28-2021 at 08:05 PM.. |
![]() Buy a Toyota.
- Stock PSI Or Bust -
#4 |
![]() ![]() I think I'm going to continue with the build... Is it worth trying to "drain" the transmission and refill it with fresh fluid? I cant give up on the car now I have done so much to it already. |
#5 |
Fought Covid and won
![]() Fill the transmission, see what happens. It's a 50 plus year old car, not a good choice for a daily driver unless every system has been gone through.
1985 Chevy TPI V8 740. ![]() |
#6 |
![]() I had a known good early BW35 transmission for years but I gave it to my Volvo indie guy who left it out for the metal man.
I think MikeJr. has one kicking around though. |
#7 |
![]() Ok. I will try. I'm a only 15 so I don't need a daily driver yet. But at this rate it seems that I may have one when I'm done.
#8 | |
Burnt Sierra Madre
![]() Quote:
#9 |
![]() I think If I had to change the actual transmission, I would try for a M40 or M41 if I'm lucky. I know nothing about that at all yet though.
#10 | |
![]() Quote:
#11 |
Old and boxy but good.
![]() I suggest you get a copy of the Haynes manual for 140 and try to find a copy of the Volvo greenbook for your car. Read them from cover to cover. It'll help you out a lot with knowing how things work. These are good cars to learn how things work on. Like many old cars yours is going to need every system checked or repaired before it's trustworthy. We call that stage zero for a car.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 435k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
#12 |
Burnt Sierra Madre
#13 |
![]() Seems like it may be time for a manual swap.
#14 |
#15 |
![]() No park? That can only happen if there is a linkage problem.
#16 |
![]() He’ll be hammering away at his transmission tunnel for a CD009 in no time.
#17 |
![]() I checked the shifting linkage and its all there and all moving up until it goes inside the transmission. I don't really know how an automatic transmission works tbh but I assume that no fluid for any amount of time can cause damage. I tried to top it off today and see if anything was different. It still has no park or reverse. I think that whatever is responsible for shifting the gears inside the transmission was damaged when no transmission fluid was present. I got a couple of suggestions from my grandpa... hes an old farmer who could get anything to run and move with enough duck tape and determination... that I'm going to try. He didn't sound too hopeful. I think it might maybe time for a M40.
Anyone want to buy a broken BW35? |
#18 |
#19 |
#20 |
![]() You're 10 years late to the party.
#21 |
#22 |
![]() anyone wanna sell a m40 or m41... I promise this time I will make sure that all the gear oil doesn't in 15 miles.
#23 | |
![]() Quote:
I've got an M40 in pieces I still need to find a layshaft for. |
#24 |
Making Volvo Parts Fit
![]() Join Date: May 2008
![]() You can't just swap the transmission. You need the pedals, shifter, (wiring, etc., if OD trans), clutch parts, flywheel, driveshaft, etc....
Just get a used BW35, or drop yours & take it to a trans shop to rebuild. Park is purely mechanical linkage lock, so something is up mechanically if it won't lock, besides all the lack of gear engagement issues. The shift linkage has a number of pivot points & bushings, so you want to try using the lever on the trans to engage park, instead of the shift lever, to confirm if the Park engagement is an external linkage issue or internal. As suggested, you need at the very least the Haynes manual, and preferably the Volvo Greenbook, you can look at all the pretty pictures & photos that show how the trans & shift work & are connected (along with all the other systems you will be fixing as you go along). |
#25 | |
![]() Quote:
