Old 12-03-2021, 06:40 PM   #1
Mr. V
Mr. V's Avatar
Default 740: vibration at 2200 RPM
My 1986 740 Turbo with manual transmission vibrates / shudders slightly between about 2200 and 2600 RPM to where I can feel a slight vibration / shaking from both the steering wheel and the shifter.
Thoughts as to possible cause?
Old 12-03-2021, 07:22 PM   #2
Kjets On a Plane
Kjets On a Plane's Avatar
Resonance from collapsed hydro motor mounts, or does yours still have 'solids' (simply rubber, not goo filled) in '86 like most do?
There's the updated bracket/trans mount that works way better in those?
How PSI a stock can support?
Always Be Crushing!
Old 12-03-2021, 10:10 PM   #3
Mr. V
Mr. V's Avatar
Solid mounts, seem OK.
What updated bracket?
Source?
Thanks.
Old 12-03-2021, 10:17 PM   #4
Kjets On a Plane
Search brickboard IDK?
It allows you to use the same 'sunken' trans mount the (later) 7/9 AW cars use with the M46, works well with the solid mounts, the M46 doesn't flop around like a fish in the trans tunnel anymore.
I think I sold my last NOS one, may no longer be available.
Or PM sbabbs? He's local & I think has said bracket that's only used on some late M46 700s.
But he might not want to break any of his 7/9 manual trans specific stuff up?
The late 7/9 auto crossmember and mount is obviously abundant.
If it's RPM based and does it neutral revving it, IDK tho? Sometimes it's a resonance thru the exhaust/messed up mount or someone installed an aftermarket cat or muffler that doesn't fit or work right or didn't get it on the hangers right or the rubber vibe-isolating exhaust hangers are dried out &/or partially or 1 of the many is compromised &/or broken?
Old 12-04-2021, 06:16 AM   #5
Fa182
Stage 1
Fa182's Avatar
Could be the driveshaft support bearing / bushing too.
Could also be something easy as wheels or tires out of balance.
Old 12-04-2021, 07:07 PM   #6
OVERDRIVE
OVERDRIVE's Avatar
I’ve had a driveshaft center support cause vibrations at 30mph but it seems like the op has an issue with engine speed not wheel speed. The accessory bushings are known to degrade and cause sagging accessories. It’s possible that a resonant frequency at those rpms is putting a strain on things.
1990 244 DL AW70 189 Polar White -hers
1991 M5 668 Schwartz II over black nappa. -his
OVERDRIVE is offline   Reply With Quote
