![]() I have a 1968 Volvo 142s with a B20 Engine that I'm swapping a m40 into yada yada yada.
I looked in both the Green book and the Haynes manual and I only found the torque spec for the flywheel being 36-40 foot pounds. Is this right? Also what are the torque specs for the pressure plate, clutch housing, driveshaft bolts, transmission mount, cross member, and any other important ones. Is thread locker recommended for any of the bolts. I don't believe the Haynes book talks about it. Also I was told to use a small amount of grease on the heads of the bolts in order to get an accurate torque speck. Bs or not? Also if I do grease specifically the flywheel bolts will I risk it getting on my clutch assembly? Lastly how should I torque bolts that I can't reach with the wrench. Is tight enough ok or do I have to find like come crows foot wrenches or something.
volvvovlovlvovovlovlvovlvovlvovlvovlvooovlovovovoo vl |
Old and boxy but good.
![]() All of the torque specs you are looking for are in the Volvo green book for your car. Do not use grease on bolts for correct torque spec. You can use light oil on the threads. Stuff you can not reach with the torque wrench should be made tight by hand. I would suggest you practice a bit torqueing some fasteners at different tightness and give yourself an idea of how tight is tight enough. Then you'll get a handle on tight enough.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 435k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
![]() thanks dude. Ill double check the book. I look for a half second and than say frick this Im going to tb where i get all my bad ideas from.
#4 |
Enough already!
![]() I'd add that it's also a good idea to clean (like on a wire wheel) the bolts before you lightly oil the threads.
Differences of opinions should be tolerated, but only if they're not too different. - Sharon Craig |
#5 |
![]() I did that. Went for a drive today. During the drive my dad stalled the car. We need some practice with the freedom box. Went to start the car and it refused to start. Battery was too dead to start. I think that alternator isn't charging the battery anymore... Ill see if I can fix it and Ill let you know later. I think the car stalled because he tried to go in third instead of first. I think the battery had enough volts to run the car but not enough to start it.
#6 |
![]() Aside from breaking down in the middle of the road, the car drove excellently.
#7 |
Bored member
![]() Wait a 14 year old volvo owner actually finished a project that spurred up 3 threads?
Can we get this |
#8 |
![]() I thought it wouldn't actually happen either. I'm 15 now though. Its kinda done. I still need backup lights and there's a hole in the floorboards where I need to put a shifter boot thingy.
#9 |
![]() An update. I reconnected the wires and the battery seems to hold at about 12.26 volts when idling for 10 min. I don't know if this is weak or not but it stayed there after dropping from 12.38v on initial start. Keep in mind also that I have a harbor freight volt meter so it might not be accurate. The point is though is that it stayed somewhere once it got warm. Lastly, the idle was a bit high and I turned it down with the idle screws. seemed to do the trick. Why was it idling high? My guess is the fact that it is a different flywheel and stuff but I don't know.
#10 |
Bored member
![]() Anything under 12.6 is actively discharging the battery but you really want ~13.2+
#11 |
#12 |
- Stock PSI Or Bust -
![]() ![]() Tha amps it takes to run the car that aren't being replaced by a faulty alternator. |
#13 | |
![]() Quote:
Similarly, flaws on bolts can sometimes be salvaged using a die. If this idea of using a tap and die is unfamiliar, see: https://www.youtube.com/watch?v=afX9EEzLK84 Harbor freight sells a reasonably priced set that is okay for occasional use. |
#14 |
![]() Another great way to repair threads on a bolt or screw is to use a thread file. They are very cheap and have four different threads on each file.
#15 |
![]() I could have tried to guess. But why guess when I can have someone tell me whats right. I'm going to get a better volt meter as well so I can see a more accurate reading. I didn't test how much voltage the alternator was giving out, I tested to see what voltage the battery stayed at after the car warmed up and had run for a while. It stayed at 12.3 volts or whatever I said. Is there a way to see how much voltage the alternator is putting out?
#16 |
![]() Test it when the car is running.
#17 |
![]() where do I stick the sharp prong things?
#18 |
![]() At the battery terminals where the voltage is charging the battery.
#19 |
![]() You stick them on the battery. Meter set for dc volts. 20v range. The alternator makes
higher voltage than the battery which results in charging the battery and supplying all the other power needs while the car is running. Your charging voltage should be at least 13.6vdc. It's better if it's slightly higher at around 14-14.4vdc. |
#20 |
![]() Ok my harbor freight voltmeter isn't cutting it than. the battery doesn't die when its running and yet it reads around 12.3 volts.
#21 |
![]() Not necessarily. While there’s a multitude of different quality meters out there, 12.3 volts is too low when charging. I’d be surprised if your meter is off by that much. You can check it out on another car. Alternator sounds suspect.
#22 |
![]() Also lights and fan on when testing.
#23 |
![]() I found a problem. The positive terminal wasn't really that tight. I though I had tightened it down enough and it wasn't tight at all. The cable doesn't get tight enough. I took it apart and also found that the cable was really rusty. Replaced the cable and the voltmeter reads 16.68v once the car is warm and driven for a bit. I still don't trust the voltmeter all that much but that's a huge jump.
#24 |
#25 |
Enough already!
![]() I think he means the heater-blower fan.
