![]() I tried to get a response doing this job the second time but no one responded so now i’ve got to go in a third time to get it right. I did not put silicone on the bottom half of the cam plug and I don't remember having to do this before. But now after a few days oil has now made its way past the bottom half consistently. I guess at this point silicone on the bottom half like I do the top is the solution.
Otherwise the only thing I can think of is the plug is pressed in too far but there there is a good distance from the facing for it to be fully on the back of the camshaft. |
Old and boxy but good.
![]() Have you tested your PCV system? A blocked system will keep pushing that plug right out.
Try to clean the contact surface of the bearing blocks where the plug goes really well. Should not need any sealant there. Last edited by dl242gt; 06-24-2020 at 09:18 PM.. Reason: add comment |
![]() PCV was cleaned out afew months ago. Its not spotty its running out pretty decently. I can check over pcv system again but the plug before was completely done. So this one should make the difference. Unless the mating surface is messed up but it didn’t appear to be
#4 |
![]() Add RTV
No Start Thread |
#5 | |
![]() Quote:
2. Is the top half of Oil Separator Box not glued to bottom half? See Pic Here |
