20220515_163202 by
P?ter Gede, on Flickr
I do like when the car is loaded (with a D5252T), sits about perfect.
So I quickly dug myself into this one. This second engine was already partially disassembled and as the garage is dusty, i wanted to close all openings as quick as i could.
I started with installing the rebuilt injectors, this needed careful cleaning of the injector sealing surfaces and the bores. Of course with the engine on the stand, turned upside down.
Checked and cleaned all the glowplugs and their seats and installed them too. Not that they are needed badly on the TDI engines... I still havent connected anything to them.
20220520_000423 by
20220520_030005 by
Then went to the other side, after some careful cleaning I installed the flipped intake manifold:
20220524_204707 by
Installed the Audi exhaust manifold along with its K14 turbo and drain tube. Took my time and fabricated the EGR connecting flex pipe too, to look original. I think its from the D5252T engine as it has a very long flex part. It needed some brute force but it bent to the needed place well. Its blocked now though as there is nothing to actuate it.
20220526_010136 by
20220526_010154 by
Went along with removing the D5252T oil cooler adapter casting, and installed the D24TIC one which is already turned upwards a bit:
20220526_010142 by
This greeted me with this sweet and easy job for the oil feedline.
For the top section, it uses the Audi feedline, for the bottom very small section it uses the D5252T turbo side feedline:
20220526_185439 by
20220526_185444 by
After some TIG madness and polishing later:
20220526_191159 by
20220526_193917 by
Turned the engine upside down again, continued the oil pickup tube. I had no intact old design metal pickup ends with the fine filter, so i went with the newer design, which has a more coarse filter:
20220601_223217 by
20220601_223250 by
20220601_233913 by
Then the problems began as these went a bit too well. In the national Audi C4 group, i saw a lot of guys struggling with loosening and breaking the crank main bearing cap bolts in the 5pot 2.5TDIs. Not all of the bolts, but mainly the second and third ones are the ones which let go.
There is no consensus about the culprit, heavy guesswork of the group was focusing on worn harmonic balancer pulleys, worn dual mass flywheels, some guys think it was surely because higher power outputs...
Some guys said its perfectly okay after 400-500tkm in stock engines, and that it just needs to be changed regularly. I was on the other end, that its not at all acceptable for a non moving part to just simply loosen up and eventually break, and that it needs to be replaced regularly. Nobody found correlation between tuned engines and the loosening. Some people had them break while they were just casually cruising at normal speeds.
Bulletproof TDI engine hah?
Bolts are fully threaded M10x80 10.9, flanged hex head bolts.
At this time I still thought going 12.9 is the way to go. Ordered them, went along and found that 2. and 3. cap bolts came loose a bit too easy...
Moved on anyway, changed bolts without removing the caps. Two by two. Oiled the bolts and torqued them. Then something weird happened because at the second cap, the crankshaft seized after torquing. I was not happy...
20220604_231103 by
20220605_003810 by
The bearing looks perfectly fine for a 500tkm engine, but why does it seize up the crank?
After some time in that fb group, a dude mentioned the same scenario but after a broken bolt. He said they hammered the cap until the crank turned freely, assembled the engine, idled it for a hour, changed oil. They started using it, but without revving over 2500rpm. After 5000km, another oil change. They have been using it since then, without any problems, with some mods, on the limiter, for four years now... I was like, what can I lose with trying it too.
Torqued to 80Nm, then started hammering on the cap. Indeed the crank eventually got free. Hammered a bit more, it became better. Still not perfect, but thought it will make room for itself.
20220605_163437 by
Had to to something about the dipstick situation. Checked the angle and position of the bore, and it was the same as the D24. Created this piece of art D24 dipstick calibrator:
284641300_1402494810174065_6020745926237333931_n by
This way, with using the D5252T dipstick housing and a redblock dipstick, i needed to remove (iirc) 10-15mm from the housing to get it right.
And the final assembled bottom end with a new PTFE rear main seal:
20220606_004213 by
