Old 11-21-2020, 08:10 PM   #1
spock345
spock345's Avatar
Default HIF6 vs HS6
I am trying to decide on which carburetors to put on my 122s in place of the weber DGEV that is currently on it.
I have a set of HS6 carburetors from an early 60s 122 or 544. They should have the correct needles for the car. The caveat here is that the throttle shafts have a good amount of play.
I also just acquired a set of HIF6 carburetors with the linkage and airbox that are from a 70s 140 (I think). There is virtually no play in the throttle shafts on this pair. From a cursory inspection these seem to be in much better shape, even if they are completely filthy.
Is there any reason not to go with the HIF6 given that the throttle shafts aren't bouncing around. They seem like a better design.
The motor in question is a B18D that I will be bumping up to B18B compression and a D cam.
1967 122s, B20F, M40
Old 11-21-2020, 11:03 PM   #2
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
IMO, I'd run HS6's. Simpler, easier to get parts for, IIRC they actually flow marginally more air than HIF6's.
Then again, they're SU's so take the "better" one with a grain of salt.
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 11-21-2020, 11:44 PM   #3
spock345
spock345's Avatar
From everything I have found online the HIF6s flow a bit better than the HS6s (240cfm vs 210cfm). Although I am worried
The simplicity is a big part of why I am considering the HS carbs even though they will need machining. Although supposedly the choke is better on the HIFs.
Old 11-22-2020, 01:12 AM   #4
vwbusman66
vwbusman66's Avatar
Maybe I have them switched RE the flow advantage. IMO I'd go with the HS's, especially since you're sticking with the B18.
The chokes (if you're referring to a mechanical/manual enrichment device) on both sets of HIF's I've had sucked. Either barely worked at all or seemed to never come off entirely. Depending on the year of Volvo HIF's, you may only have a front choke like my '71 142S.
Old 11-22-2020, 01:27 AM   #5
spock345
spock345's Avatar
I think mine are from a '72 or later car as they have enrichment devices on both carbs.
Old 11-22-2020, 01:39 AM   #6
59volvo
fyi
59volvo is offline   Reply With Quote
Old 11-22-2020, 04:50 AM   #7
283SD
In my 45+ years working on cars with Skinners Union Carbs, in your case I would use the HS6 carbs, never liked the HIF carbs.
Old 11-22-2020, 12:36 PM   #8
spock345
spock345's Avatar
Interesting, while digging around I found some threads on British car forums that seem to lean towards the HIF carbs while harping on their float adjustments. I would think that setting the float height is pretty easy.
Any particular reason why?
I would just send the carburetors out to be refurbished but I rather like working on carbs and there is a plague on. The HS6s would have to go out to get machined, the HIFs throttles aren't really worn at all so I could do the overhaul without machining. I've priced out what needs to be done and the HIFs come out quite a bit cheaper.
My one big worry is the needles. The needles in the HIF carbs are BBB and the HS carbs are ZH. The ZH seems a bit lean for what I am going for (B18B compression with a D cam) and I am worried that since the BBBs were fitted to a B20B that it would be too rich.
Old 11-22-2020, 01:21 PM   #9
alschnertz
Enough already!
alschnertz's Avatar
I drove a '72 B20B (+0.030") from 1993 to 2006 year round in temps. of -10F to 100F.
Tried HS6 and HIF6 carbs.
Maybe I was lucky, but I much preferred the HIFs after they were sorted out.
They were very reliable and rarely needed any attention.
alschnertz is online now   Reply With Quote
Old 11-22-2020, 07:57 PM   #10
spock345
spock345's Avatar
So the HIF6 has a sprung needle, would it be possible to swap the an HS unsprung needle into a HIF?
Edit: The piston from one of the HS6 carbs fits in the HIF. So I think I could theoretically run a HS6 needle in a HIF6 carb. Giving me access to the B18 specified needles.
Old 11-22-2020, 09:00 PM   #11
alschnertz
Enough already!
alschnertz's Avatar
Posted something and then realized it didn't really answer your question.
Whoops.
Old 11-22-2020, 10:00 PM   #12
spock345
spock345's Avatar
Well I have been looking at the specs. A 100HP B18D, which is what I've got should have either SM or KG needles.
I found a site that rather nicely plots the taper of each needle. https://classicminidiy.com/technical/needles
Comparing the BBB, KG, and SM needles shows the SM and BBB to be pretty close with the BBB slightly richer. The KG is quite a bit leaner than either the BBB or SM. I bet I could get away with it given I am running a better exhaust. Maybe.
At this point I would like to run the HS6 carbs but I am trying to figure out if it is feasible to run the HIF6s until I can sort out the throttle shafts.
Old 11-23-2020, 01:34 AM   #13
planetman
planetman's Avatar
You probably can.
But besides having to dial in the HIF6s, you will have to sort out the linkage.
We usually install KD needles in HS6 carbs for a B18 with a D cam.
We prefer to rebuild our own SU carbs and we try to keep all the parts needed for rebuilding in stock, but the 1 step we outsource is throttle shaft and bushing replacement.
And to reduce wait times for our customers, we usually have all 4 variations of rebuilt HS6 SU throttle bodies with new throttle shafts in stock.
Eric
Torrance, CA 90502
Old 11-23-2020, 02:17 PM   #14
spock345
spock345's Avatar
Originally Posted by planetman View Post
You probably can.
B18B or D? Does compression have a significant impact on needle choice?
I have all the parts for the HIF6 linkage. I actually have to find a linkage and springs to make the HS6 carbs work.
Old 11-25-2020, 07:31 PM   #15
klr142
Turbo, what?
klr142's Avatar
I had the HIF6s on my B20B/B20F back in the day and enjoyed them. People think they're more troublesome to set than the HS6s supposedly, but I was fine with them. I had them gone through before installing to replace my DGV, though. The HIF6s are not going to be "too large" for your B18B/D cam setup.
Old 11-25-2020, 07:34 PM   #16
spock345
spock345's Avatar
Ok, that is good. I will probably be rebuilding both sets of carburetors (although the HIFs don't need much). Then I can experiment and see which ones I like more. I'll record how the BBB needles do on a B18.
Old 11-27-2020, 10:48 AM   #17
OttoB
David Vidards book How to tune BL-A engines has good portion of good SU modification tips, hints and flow results.
Old 12-01-2020, 12:35 AM   #18
59volvo
fyi
https://www.sucarburetors.com/products
Old 12-01-2020, 12:09 PM   #19
spock345
spock345's Avatar
Originally Posted by 59volvo View Post
I am doing most of the work myself. Except for the throttle shaft bushings. I am though contacting them about the concentric throttle spring parts they offer for HS6 carbs.
Old 12-01-2020, 01:32 PM   #20
Harry Tuttle
Good idea. Those straight-pull extension springs are what wears out the bushings, in my opinion.
Originally Posted by sbabbs
Old 12-01-2020, 02:41 PM   #21
spock345
spock345's Avatar
That is my theory as well. When I took mine apart the side with the spring was more worn than the other side. It is probably one of the reasons why HIF shafts last longer. Along with not having brass on brass moving parts (relatively high friction coefficient).
Old 12-01-2020, 02:51 PM   #22
Worse than brass on brass, it's brass on cast alu on the HS carbs. This may have worked better with leaded gas (purely a guess? But maybe some evaporated fuel ended up in that area and helped?). Or they just never expected the Brit cars they were normally bolted to to last long enough for it to be an issue.
Old 12-01-2020, 03:02 PM   #23
spock345
spock345's Avatar
I ended up sending the carb bodies out to Tom Bryant in Maine who replaces the brass with delrin for a decent price. I heard good things about his work. I think any modern option whether it be PTFE, oilite bronze, or delrin would be an improvement over the stock setup.
I'll post some pictures when I get them back.
I wish I had a drill press and reamers or I could be doing this work at home.
Old 12-01-2020, 07:33 PM   #24
klr142
Turbo, what?
klr142's Avatar
That's who(Rhys) I had do my HIF6s! He was very helpful and happy to help with setup tips as well.
Old 12-02-2020, 12:46 PM   #25
cwdodson88
Rhys is the only person I will send stuff to anymore. Had 3 different people "rebuild" sets of carbs for me for different cars, Austins, MG's, Triumphs... Rhys was the only one that I did not have problems with, either right at install, or later down the road.
The Build Thread
SVEA - PUSHROD TURBO!
