Old 11-14-2022, 07:53 PM   #1
eebird
Default What does this warning light indicate / 92 240
eebird is offline   Reply With Quote
Old 11-14-2022, 07:54 PM   #2
the_hairy_baboon
Would that be the bulb failure indicator telling you one of your outside illumination bulbs has failed?
the_hairy_baboon is offline   Reply With Quote
Old 11-14-2022, 08:14 PM   #3
^^^ correct!
You can also find an owner's manual at: http://www.volvotips.com/index.php/2...260-brochures/
Old 11-14-2022, 08:19 PM   #4
eebird
Thanks!!
Old 11-14-2022, 09:24 PM   #5
spock345
spock345's Avatar
Or it could be that the bulb failure relay has failed.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
Old 11-14-2022, 09:36 PM   #6
James M
Bored member
James M's Avatar
Or your car stalled and non of the other lights work
James M is online now   Reply With Quote
Old 11-15-2022, 09:50 AM   #7
doucheNozzle
doucheNozzle's Avatar
Moar blinker fluid plz
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
‘12 Mazda5 - Work Car
‘06 E350 Ambulance - Work Car
It says so on the lens.
Old 11-16-2022, 04:19 PM   #8
Sudan or wagon?
Old 11-16-2022, 04:22 PM   #9
eebird
wagon, I figured it out thanks you this forum, just a taillight bulb out. Replaced it.
Old 11-19-2022, 04:10 PM   #10
nel621
It's the "here's an idea, sell this thing" warning light.
Old 11-19-2022, 05:12 PM   #11
atikovi
That light starting coming on in my '86 when stepping on the brake and right after replacing the left tail light. The brake lights work fine, although the new one looks slightly brighter. Is this from the module sensing the difference in resistance in the circuit between right and left? Should I swap in the bulb from the old left light to make the warning go away?
atikovi is offline   Reply With Quote
Old 11-19-2022, 05:19 PM   #12
Sedans suffer from issues with the flexible circuit board and the bulb holders. Wagons have issues with the bulb holders. Aftermarket lamps and bulb holders make things even worse.
The relay measures the "balance" of the current from left to right. If one side has more/less current, the warning light comes on.
I have heard of issues with different brand bulbs on each side causing an issue. Or if a ground connection is poor on one side.
The lamp means, "I drive an old Volvo with never ending electrical issues"
Old 11-20-2022, 11:42 AM   #13
DD Ranch
DD Ranch's Avatar
It comes on when I hit the brakes on the 91 wagon with the broken tailgate harness and resultant lack of the cyclops light.
But I have come to like it and look at it as part of the cars "character".
Maybe one day I'll fix it.
Florida Chapter VCOA
DD Ranch is offline   Reply With Quote
Old 11-27-2022, 12:36 PM   #14
dbarton
Dejected by Volvo Corp.
dbarton's Avatar
No one guessed the correct answer.
The correct answer is it's a critical warning, telling you to reach in behind the cluster, twist and remove that bulb. Then carefully walk outside and throw it as far as you can.
Then go about your life.
Dave
'84 242ti, fourth owner, mine since 2003. Garaged since new. Old-school rounds because. B21FT, EMS: SDS EFI & IGN, TD04HL-15G turbo, T5Z trans with 0.73 OD, 3.91 diff, unmodified G80.
Volvo's Ambivalence of Volvo Enthusiast Community: prancingmoose.com/#novolvo
Old 11-27-2022, 12:47 PM   #15
I don't think the 3rd brake lamp is included in the circuit. There isn't another "side" of the circuit to compare current with.
Old 11-27-2022, 01:00 PM   #16
atikovi
Mine stopped coming on. Did the module learn the new bulb's resistance and adjust for it?
Old 11-27-2022, 01:36 PM   #17
Old and boxy but good.
The module does detect the third brake light being out. So, if you fix the tailgate harnesses the light may start behaving itself. Or, like in my car it keeps coming on randomly even though you have cleaned connections and have the same bulb in each side of the car. All lights are working nomially.
Old Today, 04:57 PM   #18
OVERDRIVE
OVERDRIVE's Avatar
I'm trying to get to the bottom of this on my car too. I've got it so now the light only comes on when I brake. Auto Zone said my brake lights are 7258 which is 26.9w and 7506 which is 21w, versus the 1157 21w and 1156 21w that the owners manual calls for. I'll get the 1157's tomorrow but I figured I would ask here before hand to get some more tips.
1990 244 DL AW70 189 white.
OVERDRIVE is offline   Reply With Quote
Old Today, 05:02 PM   #19
The old dual filament bulb designation was 1073 which is also still available. I use them for a bit less heat vs using the 1157 bulb. I just
noticed on my car today the left running light bulb is somewhat less bright than the right. So, when it stops raining I have some connections to clean.
