Old 10-01-2022, 06:13 PM   #1
philski o'flood
philski o'flood's Avatar
Default 240 Rust inside under windshield / cowl area
Ok so a blower motor job has turned into let's clean everything, convert to '93 AC and add dyna mat / sound proofing.
But now I gots some rust. The windshield is old and leaky and will be replaced but what should do about this stuff???
Is it coming in through the crimped edges where body and cowl meet?
I have a bottle of rust neutralizer.
Ok thanks.
philski o'flood is offline   Reply With Quote
Old 10-01-2022, 06:49 PM   #2
nel621
I would grind it, neutralize it then fiberglass it and paint.
Old 10-01-2022, 07:52 PM   #3
Old and boxy but good.
Or if you want to try something instead of fiberglass. You could use this after the grinding and rust neutralizing. Lab metal. https://www.ebay.com/itm/17542912526...3ABFBMyv6q3_Jg
Old 10-01-2022, 10:37 PM   #4
white855T
I've had to do that. Clean it up as best as you can. Rust neutralizer, and prime it. I use seam sealer after that. You can paint afterwards to match if need be.
Old 10-02-2022, 12:14 AM   #5
philski o'flood
these are good suggestions thanks. But where is the water coming from and is it possible to stop it?... is there rust on the other side of that seam?
Gawddanm it I'd meaning to ask him for months. fawk
Old 10-06-2022, 03:55 AM   #6
bgpzfm142
crossmember
bgpzfm142's Avatar
Greg (carnut222, both here and on Oz Volvo) found a very similar water leak in almost exactly the same place.
Here in upside-down land, that hole in the RH side of firewall in your first pic is almost exactly where the hood release cable passes through in our cars, since RH is driver's side here.
Here's a link to Greg's post, where he describes the problem (basically poor body sealing in the A-pillar joint) and the fix.
https://ozvolvo.org/discussion/comme...Comment_201581
_______ THE FLEET (AKA good luck trying to park around here)
71 1800E | 73 144 | 74 142 | 74 145 | 79 242GT | 85 244 | 88 780 V6 | 93 945T | 96 965 | 2010 S80 V8
plus a Holden Commodore VT SS 5.7
feedback thread
bgpzfm142 is offline   Reply With Quote
Old 10-08-2022, 09:34 PM   #7
Alan29
Alan29's Avatar
Ah crap...I think I have a similar situation with a gap by the hood hinge and rust inside but further down. I too am curious about rust inside the cavity and how to stop it without major surgery.
Signature.
Alan29 is offline   Reply With Quote
Old 10-17-2022, 07:28 PM   #8
philski o'flood
update... just got done with the dremel and it wasn't hardly anything, just some surface, nothing deep... whew
Old 11-22-2022, 09:49 PM   #9
philski o'flood
got the rebuilt '93 HVAC box installed today
