Old 11-07-2022, 10:58 PM   #1
okoye
okoye's Avatar
Default 1995 940 Na to b230FT swap no start
So I've got a 1995 Volvo 940 non turbo that I've swapped to Turbo (complete motor) that I'm having issues getting started. I've changed radio suppression relays, I've changed crank sensors, I've tested for spark (which I have) I jumped the pump to send fuel to the rail. Still wont start.
Any suggestions?
does anyone have pics of their RSR wiring for a 95? I can find pics for the older ones but nothing for the newer 95. I need this car started ASAP
Old 11-07-2022, 11:05 PM   #2
apachechef
Burnt Sierra Madre
resistor pack?
Dammit, Lummert.
Old 11-07-2022, 11:12 PM   #3
okoye
okoye's Avatar
No resistor pack I’m running injectors from a fwd model
Old 11-07-2022, 11:28 PM   #4
bobxyz
bobxyz's Avatar
Did you touch the timing belt or distributor during the swap?
You can still find the Mitchell's wiring diagram at https://web.archive.org/web/20160320...ing%20Diagrams
Old 11-07-2022, 11:31 PM   #5
okoye
okoye's Avatar
If I remember correctly the distributor on a head mount does not affect the timing but I could be wrong
Old 11-07-2022, 11:32 PM   #6
Mylesofsmyles
A Member
Here's some info on the Radio Suppression Relay, and led me to figure out how to bypass it during a diagnosis like yours.
https://volvoforums.com/forum/volvo-...y-74098/page2/
You have spark...is it a strong spark?
Have you thrown some starting fluid at to see if it'll run?
Do you have power to your fuel injectors when cranking? Noid light?
Does your motor have compression?
Old 11-08-2022, 12:01 AM   #7
white855T
I would guess the wiring is shot on the rsr and its not letting the injectors fire. Very common issue.
Old 11-08-2022, 09:59 AM   #8
Test lamp and starting fluid. Click my sig.
Old 11-08-2022, 10:47 AM   #9
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Does it smell like it's getting fuel? Did you crack the line at the rail after cranking?
What about the ECU? Is it know good from a running vehicle? You can always plug in the NA ECU just to test start...
My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread
lookforjoe is online now   Reply With Quote
Old 11-10-2022, 02:33 PM   #10
okoye
okoye's Avatar
Does anyone have pictures of a 1995 940 radio suppression relay?
Old 11-10-2022, 02:45 PM   #11
2manyturbos
IIRC, the NA 940s do not have a RSR.
Old 11-10-2022, 08:19 PM   #12
bobxyz
bobxyz's Avatar
If you go back further in time, the Wayback Machine also has a '95 greenbook TP3908202 940 1995 Wiring Diagrams.pdf
https://web.archive.org/web/20131105...ing%20Diagrams
(note: some pages aren't scanned; the 94 greenbook may be better)
pdf pg 13 shows the NA RSR relay, part 2/12, and the fuel injection relay, part 2/23.
pdf pg 14 shows the Turbo RSR relay, part 2/12, and the fuel injection relay, part 2/13.
pdf pg 7 shows the RSR locations in the engine compartment (left NA or right turbo)
The relay itself is weird rectangular box with an offset connector and 4 round pins - I think it's this one
Old 11-10-2022, 08:28 PM   #13
lookforjoe
lookforjoe's Avatar
So - it appears to be identical to every other year suppression relay - what made you think it was different for the '95? Do you have a pic of what you're looking at?
Old 11-11-2022, 02:42 AM   #14
okoye
okoye's Avatar
So the wiring colors on the rsr is different than earlier models.
I found out the issue was that the ecu I was using was not priming the pumps with key on. I swapped for an earlier lh2.4 turbo ecu and the car fired up. I've got a few more things to sort out namely a clutch fan and some other odds and ends
Old 11-11-2022, 01:11 PM   #15
Mylesofsmyles
A Member
Glad you got it running!
Old 11-14-2022, 04:05 PM   #16
okoye
okoye's Avatar
Yeah but now I’m having issues almost as if the car is cutting fuel/ spark
