Old 11-10-2022, 01:26 PM   #1
J_pelchy
Turd Blow Bricks
J_pelchy's Avatar
Default Blower motor still runs when key off, '91 245
I can still turn up the blower motor on any speed even when the key is off on my '91 245.
I'm having a draw that's killing my battery and this is one majorly noticeable thing I'm seeing. Any idea what's causing this?
Thank you
Flint, Mi
*Volvo Enthusiasts of Michigan*
Instagram // 810_volvos
Feedback
J_pelchy is offline   Reply With Quote
Old 11-10-2022, 01:29 PM   #2
Old and boxy but good.
At just a guess. I would check the fuse box for the wiring being connected to the wrong fuse. The power feed to the fan is a large white/black wire and should go to a switched power fuse.
Old 11-11-2022, 05:54 PM   #3
MasterBlaster
MasterBlaster's Avatar
The blower should be run by fuse #3, powered from terminal "X" on the ignition switch.
"X" also powers fuse #1 and #2; the other things included as "accessories".
Do the wipers also work with the key "off"?
How about the radio, or horn?
1990 740GL
545,000 km so far...
Old 11-12-2022, 11:10 AM   #4
J_pelchy
Turd Blow Bricks
J_pelchy's Avatar
they all actually do too, yeah. So I should probably try a new ignition switch it seems.
Thanks for leading me in that direction.
Old 11-16-2022, 04:20 PM   #5
Shorted resistor wiring
