Old 11-15-2022, 02:49 PM   #1
eebird
Default 240 wagon tail lamp assembly replacements
I gather there are a lot of aftermarket brands/versions of these available. Can anyone recommend one that is the best to get, for fit or quality? Or are they all basically the same? I see IPD sells some, also FCP Euro. Some on ebay and Amazon as well.
eebird is offline   Reply With Quote
Old 11-15-2022, 02:59 PM   #2
Johnnya101
I -THINK- the ones I got are Swedish Auto Lamps. Bought on ebay. Great quality for the price. Only thing that bugs me is one orange lens is a slightly lighter color...
HAVE
1991 245SE here
SOLD
1988 240DL Sedan
Johnnya101 is offline   Reply With Quote
Old 11-16-2022, 12:20 PM   #3
Old and boxy but good.
First choice would be nice condition used original. If you must have new then the genuine Volvo ones are the best. I've used the Swedish Car Parts ones on my 93 and they are very nice. Use a 1073 bulb in the bottom location instead of an 1157 to help keep the light bulb heat from melting the plastic.
Old 11-16-2022, 12:32 PM   #4
283SD
I got a pair from IPD they seem to be well made.
Old 11-16-2022, 01:11 PM   #5
white855T
They are still available from Volvo. Left side https://www.volvopartswebstore.com/p...8/1372441.html right side https://www.volvopartswebstore.com/p...3/1372442.html
Swedish car parts are good replacements but they do fade after about 5 years.
Finding good used ones is great option. Post a wanted post or look on ebay.
Here is a nice pair on ebay. https://www.ebay.com/itm/40397463668...Bk9SR6TS2ZaQYQ
Old 11-16-2022, 01:21 PM   #6
Khrrck
Professional Amateur
Having used both "good used" and "aftermarket" options - I found that the aftermarket ones were cleaner and nicer looking IMO, and less likely to have surprise melted contacts or back plastic.
That said - they don't come with bulb holders and used ones often do. Buying new bulb holders is $$$ if you aren't reusing your old ones for some reason. And the aftermarket options are kind of expensive too.
If you are concerned about UV fading (I never had an issue with mine) there's a lot of good spray or wipe-on clear coat products which are for protecting plastic lenses against UV. Usually they're sold as headlight protectants. I think you can get a film too but that sounds like a pain.
Bonus tip - The upper rear foglight position can be populated on both sides and wired up to your brake light circuit so that you have 5 total brake lights for better visibility.
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 11-16-2022, 03:47 PM   #7
Last time I ordered volvo genuine part 245 tail lamps, they were made in Taiwan non cibie tail lights.
Was not impressed with the quality unfortunately.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-16-2022, 03:55 PM   #8
2manyturbos
^^ No surprise. Almost everything Volvo sells for the 240 is an aftermarket part. Their Genuine Volvo down pipe is a piece of crap Walker relabeled. Same thing with their "OE" exhaust systems. Relabeled Walker junk. Their strut mounts are pure garbage. Most likely made in China. A pair lasted less than 5,000 miles/2 years on mr brick driver's 242.
I have experienced the complete opposite situation with the tail lights, both sedan and wagon. OE Volvo lights have never melted a socket. With the aftermaket lights both the sedan and wagon lights almost always melt the dual filament bulb socket.
Old 11-16-2022, 04:13 PM   #9
The aftermarket sedan tail light circuit cards are so thin. It's amazing there is enough material to have the copper trace on it. If you poke too hard with your finger you'll tear it. Instead of the socket melting I've seen the circuit card melt.
Old 11-16-2022, 08:34 PM   #10
Khrrck
Ah sorry if I was unclear. OE lights probably have thicker plastic. Maybe I just have had bad luck with sourcing "good used" but I managed to get two beat-up pairs in a row and one of them had a melted socket. (Was looking for replacements since the ones on the old budget wagon had melted on both sides).
Secret to avoiding socket melt IMO is good clean contacts on both the holder and lighting assembly, and good spring tension if you can help it. You can also reduce the amp load with LED bulbs but then you have to deal with the failure relay.
Those flex PCBs on the sedan lights sound terrible. I think even if I got a nice OE one I'd want to hardwire it. But I've been avoiding sedans like the plague this whole time.
Old 11-24-2022, 05:14 PM   #11
atikovi
I was looking for a used one a few weeks ago but people on Facebook, Craigslist and Ebay want stupid money for faded and cracked examples like this one for $73 with shipping: https://www.ebay.com/itm/12549882199...temCondition=4 Maybe for $25 or $30 it would be ok for a beater, but no thanks. Bought this brand new one for $75 and it was plug and play: https://www.ebay.com/itm/31352065893...Bk9SR5bF6beVYQ
atikovi is offline   Reply With Quote
Old 11-26-2022, 05:47 PM   #12
hessam69
What can be done about the thin aftermarket circuit board? Or are OEM new taillights available?
Old 11-29-2022, 03:43 PM   #13
go240go
I've been using the Swedish Car Parts tails on my 245 for a few years so far. I went with LED's for the running and brake lights (bottoms are running and brakes, and wired top fogs as brakes), and left the turns and reverse as halogens. I wired the bulb holders directly to bypass the issue-prone circuit board. I haven't seen any melting yet, and no longer have intermittent bulbs going dark due to inconsistent contacts like I did with the old tails.
1987 245DL
go240go is offline   Reply With Quote
