Old 11-23-2022, 01:59 PM   #26
2manyturbos
Originally Posted by atikovi View Post
Threads look fine,
Anybody know the torque spec for the M6 pan bolts or where to find it?
Good. Use some anti-seize compound on the threads when you put it back together and they should stay that way. 50-60 inch*lb for the pan bolts is what I think I remember reading somewhere. It isn’t much.
Old 11-23-2022, 02:42 PM   #27
leecatd8209
https://www.amazon.com/Volvo-Service...=UTF8&qid=&sr=
If you plan on keeping the car, buy this book
leecatd8209 is online now   Reply With Quote
Old 11-23-2022, 02:50 PM   #28
spock345
spock345's Avatar
Last time I did a transmission pan gasket on an AW70 it was something like 8-10 ft-lbs.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
Old 11-23-2022, 02:50 PM   #29
atikovi
The book said 36-39 in lb. which seems awful low, maybe a misprint. Most M6 bolts on transmission pans are 80-90. Went for 70.
atikovi is offline   Reply With Quote
Old 11-23-2022, 03:49 PM   #30
2manyturbos
I just checked the Bentley Bible and found the same spec. It's much higher with the paper gaskets. The low torque spec is to keep from distorting the pan and squeezing the gasket out between the bolts. I usually go with 60 in*lb as a happy medium between the specs. 36-39 in*lb is so low I'd be concerned the bolts might back out. Make sure to re-torque the bolts in the next day or two. Once everything heats up that gasket will compress quite a bit.
Old 11-23-2022, 03:59 PM   #31
hessam69
The book says 4-5Nm.
Too loose, they will loosen at that torque. Try 7Nm
Old 11-23-2022, 04:18 PM   #32
The Librarian
Eidt: the spec for AW70/71/72 is 4-5 Nm. The following is for BW55/AW55. Whoops.
The 200 series greenbook has different torque values depending on the color of the gasket?
The 700 series greenbook only shows the 4-5 Nm (3-3.5 ft.lb) spec.
http://hiperformanceautoservice.com/...orqueSpecs.jpg
Old 11-23-2022, 05:28 PM   #33
atikovi
Used a Toyota gasket to 70 so hoping no leaks.
Old 11-23-2022, 06:44 PM   #34
spock345
spock345's Avatar
So what I am hearing is 0.5 ugga-duggas?
