Old 11-20-2022, 11:51 AM   #1
spock345
spock345's Avatar
Default Hourglass bushing removal or installation
I haven't dealt with the hourglass shaped bushings before and now have a set of torque rods with them. They seem like it would be easier to remove and install than the standard cylindrical bushings with the metal sleeve. Is that the case?
Is the prevailing guidance to still go with poly for the torque rods and rubber on the trailing arm? The goal for the car is comfortable long distance driving with a load in the back.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
Old 11-20-2022, 01:40 PM   #2
Old and boxy but good.
I would use the rubber bushings for the earlier setup like that. They are solid rubber and if you are looking more for the comfort side of things they work well. I usually install and remove them with a large vise. Some lubricant and they usually install easily.
Old 11-20-2022, 02:58 PM   #3
white855T
Bench vise will get them in and out. You have to fiddle with them but they come out and will eventually go in.
Old 11-20-2022, 08:14 PM   #4
spock345
spock345's Avatar
Nice, well between the hourglass bushings and my new TAB tool replacing any bushings should be pretty easy this time around.
Old 11-21-2022, 12:39 AM   #5
gsellstr
gsellstr's Avatar
Definitely grease the hell out of poly if you go that route, or some soapy water for the rubber ones to make your life easier...
RIP
Ken Rogers "Redwood Chair" 9/26/2022 - 'Raise the lowered', and always 'Return it to stock'
Nick Fengler "fengler" 8/6/18
74 144
90 745Ti
Still your local Superpro dealer!
Old 11-21-2022, 01:29 AM   #6
planetman
planetman's Avatar
IPD has been selling AquaLube waterproof grease for their poly bushings for as long as I can remember and they still do and that's what we use and recommend.
We use a silicone spray lubricant we get from our local Ace hardware store to install the rubber hourglass bushings.
Eric
Torrance, CA 90502
Old 11-21-2022, 05:56 PM   #7
That grease works great. But it sure has some greasy strings coming off it. They get everywhere if you aren't super careful.
