Good info from this guy. check out a few
https://youtu.be/ZdigwBNKFfI
Yes, cut out he damaged section. Measure twice cut once , get a good close fit. Then spot weld here and there until all done , grind and body work and done. Keep the welded are cool. @ , 3 welds, cool, 2,3 welds, repeat.
Thank you for the tips. This is definitely the least expensive option, albeit the most involved. Finding a fender from a 240 is easy enough. So the front matches the rear enough that I can chop and swap the arch?
$54.47 plus tax for 1.
Post a pic of your issue.
I wanted to post a few pictures to show how extensive the damage is. I used my heat gun and a chisel to dig out some of the Bondo. I cannot believe how much I used back when. I remember there being some rust damage, but it is more severe now. Seems like alot of the arch is rusted out now.
I used a paint pen to outline the damaged area, and I marked my estimated depth of Bondo, IOW how far the dent would have to come out in that area. So I now know that the arch will have to be cut out regardless... My two options are to either get a 244 wheel arch panel, cut out the damaged metal and beat out the rest of the panel, and that would be a total of $80 or something. OR I can do 7 hours of driving to go grab the entire quarter panel that Rainbow has for $300.
Does anyone know how the quarter panels are attached? Are they just spot welded on?
I am hoping that some of you more experienced with body work can give input on the best option and how to go about this repair. Thanks! https://i.postimg.cc/3xTPNV4Q/20210512-111145.jpghttps://i.postimg.cc/76wvRc4N/20210512-111138.jpg
They are $32 ea and $22.47 shipping plus tax. Check the ad again.
