the_hairy_baboon
- Dec 1, 2021
I took my Panhard bar (1983 245 GLT) to a local shop to get the bushings replaced. I hadn't noticed it, but the bushing I got from skandix (https://www.skandix.de/en/spare-par...spension-rear-axle-panhard-rod-right/1000098/) has voids. I can't find any documentation on the orientation of the voids.
If I follow the pattern for the Torque Rods where they constrain forward aft motion and are mostly horizontal bars and have the voids on top and bottom (when viewed as installed), then the direction of constraint wants rubber all the way along for stiffness, while the other directions want way less stiffness and hence have voids. Panhard bar is designed to stop rear axle from moving left/right as it flexes, so aligning the voids roughly with the bar (given it's at an angle) isn't a terrible idea and ideally probably align with horizontal when at installed rest position?
Anyone encounter this? I'll get photos when I pick them up tomorrow (had to get torque rod ones repositioned because I forgot to tell them, one rod they did well the other was close to spot on 90 degrees off).
