Based on what?
Spent much time around them? What are the specific issues you're referring to?
Based on what you say?
Common knowledge. With the arrival of the 240 series Volvo bought the 5 cylinder version of the VW 4 cylinder n.a. diesel for Nordic market taxis and the 6 cylinder version for export..
You spent much time around them? They why don't you know?
2.0 R5 D 51kW
identification
parts code prefix: ???, ID code: CN
engine configuration & engine displacement
inline five engine (R5/I5); 1,986 cubic centimetres (121.2 cu in); bore x stroke 76.5 by 86.4 millimetres (3.01 in ? 3.40 in), stroke ratio: 0.89:1 - undersquare/long-stroke, 397.1 cc per cylinder; compression ratio: 22.0:1
cylinder block & crankcase
grey cast iron; six main bearings
cylinder head & valvetrain
cast aluminium alloy; two valves per cylinder, single overhead camshaft (SOHC)
aspiration
cast aluminium intake manifold, cast iron exhaust manifold
fuel system
mechanical distributor injection pump, indirect fuel injection into whirl chamber
DIN-rated motive power & torque output
51 kilowatts (69 PS; 68 bhp) @ 4,400 rpm; 140 newton metres (103 lbf?ft) @ 2,800 rpm
application
Audi 100 (10/78-7/89),
Volvo 240
2.4 R6 D24 51-60kW
Main article: Volkswagen D24 engine
identification
parts code prefix: 075, 076
inline six (R6/I6) diesel (D); 2,383 cubic centimetres (145.4 cu in); bore x stroke: 76.5 by 86.4 millimetres (3.01 in ? 3.40 in), stroke ratio: 0.89:1 - undersquare/long-stroke, 397.1 cc per cylinder, compression ratio: 22.0:1
grey cast iron; seven main bearings, die?forged steel crossplane crankshaft, pressed steel oil sump
cast aluminium alloy; two valves per cylinder each with two concentric valve springs, timing belt-driven single overhead camshaft (SOHC) directly acting on shim-adjustable bucket tappet valve lifters
aspiration
cast aluminium alloy intake manifold, two cast iron exhaust manifolds
fuel system
Bosch mechanical distributor injection pump, indirect fuel injection into whirl pre-combustion chamber
EWG-rated motive power & torque output, application, ID codes
55 kilowatts (75 PS; 74 bhp) ? Volkswagen Industrial Motor (761: 01/81-01/84, 751: 09/83-06/93)
DIN-rated motive power & torque outputs, ID codes
51 kilowatts (69 PS; 68 bhp) ? 1S, ACT
55 kilowatts (75 PS; 74 bhp) @ 4,000 rpm; 155 newton metres (114 lbf?ft) @ 2,800 rpm ? CP, DW
60 kilowatts (82 PS; 80 bhp) @ 4,700 rpm; 145 newton metres (107 lbf?ft) @ 2,000 rpm ? Volvo D24
applications
Volkswagen LT (CP: 08/78-11/82, DW: 12/82-07/92, 1S: 08/88-07/92, ACT: 08/92-12/95),
Volvo 240, Volvo 740
People that care about engine internals have noticed a strong VW "fambly resemblance' in the bore/stroke/ rod lengths and journal diamerters and width between VW motors and the "Whiteblocks"---but aside from that nobody around here has troubled themselves to look at bore c-c and headbolt spacing...
So yeah Kenwood Chair comments are spot on
