Old 06-28-2020, 07:39 PM   #1
matt b
Default Amazon, P1800, 1800S, etc cross member shock mount repair
I tried cramming as many key words in the title to help others find this thread.
As many of us know, the upper shock mount area of the Amazon, 140 and 1800 series cars isn't great. Of the 4-5 Amazons that I've owned and subsequent 1800 cars all of them had cracked shock towers.
Here is the repair. I use a local welding shop since I don't have the ability to cut the ¼ metal plates required. Cost is $175/cross member which may be on the low side since I do a lot of business with this particular metal fab shop.
IMG_7934
Some gloriously sketchy, porous and uneven stick welding:
IMG_7935
IMG_7965
After sand blasting, ignore the LCA's, they are just as bad and will not be used.
IMG_7991
Best place to cut is the top of the curved edge. This will allow the shock to mount at the same height as the factory location.
Enjoy the nightmares:
IMG_8208
Next step is the ¼ inch plate
IMG_8075
IMG_8074
Ignore the powdercoating and red overspray, we use this particular cradle to run cars through paint.
Old 06-29-2020, 10:02 PM   #2
IansPlatinum
IansPlatinum's Avatar
Clean execution. Need to check my cross members.
Thanks for sharing
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
