12david34
- Sep 1, 2012
- Slovak Rep.
hi there
starting this thread, becasue few month ago i did a wrong thing...
started to play with k jet,(increasing/lowering pressures on warm up regulator and adjusted mixture on fuel distributor) without any monitoring device. since then my car ran really rich and i lost lots of power..and now i need help.
in order to fix this faulty step of mine, i bought a wideband.
and it works great and now i actually can see what is going on etc.
in the mean time i was able to readjust the wur back to +/- original setting, and now the car runs much better, but its still not right, and need some more fine tuning.
now since i have this wideband i would like to know what is your opinion on the values the gauge shows me. so tell me how much did i fu(ked my k jet?
here are the values:
1 cold idle- 15,5-16:1
2 warm idle- 16,5-17,1:1
3 cruising/keeping up with traffic- 15,2-16:1
4 load/wot- when i floor it,afr drops down to high 10 or mid 11:1,engine hesitates a bit, but within 2-3 seconds it starts to climb up and then it shows from low 13s to low 14s.
(all values are +/- becasue the numbers are changing guicky)
honestly, i have no idea if thats OK to run that lean on idle or cruise..
thx for your input, if possible please post your values too, so i can compare them.
