Old 03-16-2015, 01:30 PM   #1
mhgreen
mhgreen's Avatar
Default Oh, that's what a head gasket looks like
Found this yesterday…PDX240 guided the beastly tear down. But at least we discovered a root of some of my problems.
mhgreen is offline   Reply With Quote
Old 03-16-2015, 01:31 PM   #2
Lord_Athlon
300+ Clurb
Lord_Athlon's Avatar
Head Toasted?
Yet Asher here went with...
Old 03-16-2015, 01:33 PM   #3
mhgreen
mhgreen's Avatar
Originally Posted by Lord_Athlon View Post
Head Toasted?
Negative.
Getting machined and cleaned today.
Old 03-16-2015, 01:40 PM   #4
benski
Post
Originally Posted by mhgreen View Post
Negative.
Whew!
Old 03-16-2015, 01:55 PM   #5
soclosenotnear
my coolant passages are clogged like that also. what do you plan on doing to clear those, just file?
Old 03-16-2015, 01:59 PM   #6
Kjets On a Plane
Kjets On a Plane's Avatar
The miss cold will probably go away...
How PSI a stock can support?
Always Be Crushing!
Old 03-16-2015, 02:19 PM   #7
mhgreen
mhgreen's Avatar
Indeed…just worried about the noise it was making when it happened. Not sure what noise a blown head gasket will create.
Old 03-16-2015, 02:21 PM   #8
mhgreen
mhgreen's Avatar
Probably should have done that leak-down test back when the compression figures were a little sketchy in the first two cylinders. A big 'told-ya-so'.
Old 03-16-2015, 02:37 PM   #9
745 TurboGreasel
745 TurboGreasel's Avatar
2 of those holes are still good!
Feedback
Old 03-16-2015, 08:19 PM   #10
mhgreen
mhgreen's Avatar
Back from shop…A special thanks to PDX240 for hauling everything around and sending me the pictures.
[IMG][/IMG]
Old 03-16-2015, 11:47 PM   #11
theknave
theknave's Avatar
That's the second blown gasket between 1 and 2 I've seen on there in the last couple months... is this a common weak spot?
'86 240 DL, M46 - Primer grey, yellow, silver and flat black.
'90 240 DL, AW70 - Rotting, with its guts out, on the cadaver table... the AW70 is nice tho, with a recent full fluid flush via tt 500, and an all new Yukon set of bearings (Timken) and seals at the rearend, new SKF bearings and seals at the axles.
theknave is offline   Reply With Quote
Old 03-17-2015, 08:18 AM   #12
DanMarino
I love how nice heads look when they come back from the machine shop.
How much do they charge on the left coast to clean, check, and skim a head?
Machine shops are getting scarce in the midway between Baltimore and Washington, DC.
DanMarino is offline   Reply With Quote
Old 03-17-2015, 08:37 AM   #13
SteveMD
Membro
SteveMD's Avatar
I was referred to Burtonsville Performance Machine by my BMW indy shop and they did a great job on my bare 535i head (the usual cleaning, pressure testing, blasting the ports clean of carbon, cleanup skim) I did the valve lapping myself.
Address: 5210 Minnick Rd, Laurel, MD 20707
Phone:(301) 490-3131
Old 03-17-2015, 11:01 AM   #14
mhgreen
mhgreen's Avatar
$50
Old 03-17-2015, 11:02 AM   #15
Mr. V
Mr. V's Avatar
A local machine shop charged me $40 recently.
Old 03-17-2015, 11:39 AM   #16
DanMarino
Thanks Steve,
I've used them twice and they happen to be nearby. Yes, they were great. From talking to them, they indicated shops have gone out of business because people don't have engines rebuilt like they used to do. I guess when interference motors bust a timing belt these days, people junk the car or put in a different engine. They said their main customers now days are folks who need engines built for racing.
Tom
Old 03-17-2015, 05:08 PM   #17
theknave
theknave's Avatar
Enter throw-away generation.
Old 03-17-2015, 09:17 PM   #18
mhgreen
mhgreen's Avatar
That's exactly what I am fighting against. I "should" have thrown this car away the day I bought it.
Old 03-17-2015, 09:40 PM   #19
122power
dude
122power's Avatar
The WWD's are throwaway cars
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 03-17-2015, 09:53 PM   #20
240s rock
WWDs ? Sorry for the ignorance.
240s rock is offline   Reply With Quote
Old 03-17-2015, 10:26 PM   #21
pshnfry
pshnfry's Avatar
Wrong Wheel Drive
pshnfry is offline   Reply With Quote
Old 03-17-2015, 10:45 PM   #22
mhgreen
mhgreen's Avatar
Any thoughts on the "knocking" noise that I was hearing when the head gasket blew out? I just don't want to slam all this back together and hear some lower end terror
Old 03-17-2015, 11:54 PM   #23
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
eh not likely to be an issue, could have been induced by the cross talk between cylinders. I blew one between 2 and 3 once and thought I'd spun a bearing.
Megasquirt Tuning!
Old 03-17-2015, 11:55 PM   #24
iHateVolvoPeople
There was another member who blew a headgasket and heard an awful knocking noise as well..I think it went away after he replaced the head gasket
Feedback Thread
White liberals are the scum of the earth.
Old 03-18-2015, 12:25 AM   #25
mhgreen
mhgreen's Avatar
That's really reassuring. Only time will tell, but its good to know.
