Old 02-28-2016, 05:29 PM   #1
PardoR
PardoR's Avatar
Default Whining noise on the rear diff. -240 N/A 1993 AT-
Now that the car is on use, now I realize many things not noted before.... Obvioulsy because most of time was parked.
So after all the injection issues solved, I note the car makes a "screech" coming from rear, when it turns on corners and when down hills (I'm ok?) .
Did some research, the rear differential is whining.
My little research was about the noise.
I dont know nothing about differentials, just basics and function principles, but in Volvos is my first approach.
Some owners recommend change the oil. Which one fits for my car? There is a procedure? How to do it? Is an DIY task?
Thanks masters
PardoR is offline   Reply With Quote
Old 02-28-2016, 05:32 PM   #2
PardoR
PardoR's Avatar
I can record some sounds if neccessary.
Other idea: do I need a new diff.????
Old 02-28-2016, 06:28 PM   #3
iHateVolvoPeople
Make sure it's coming from the differential. It's likely that it could be the center support bearing for the driveshaft.
Feedback Thread
White liberals are the scum of the earth.
Old 02-28-2016, 06:44 PM   #4
PardoR
PardoR's Avatar
I have read about the whining on turns... The center bearing can do this too?
Old 02-28-2016, 08:20 PM   #5
iHateVolvoPeople
Like turning left or right? I would assume that's coming from the front end of the vehicle, but I'm not sure. Perhaps a video would help some people on here tell you what it is.
Old 03-05-2016, 08:47 AM   #6
PardoR
PardoR's Avatar
Mistery solved: was a socket on the bolt that holds the rear strut and was stucked between the bolt and the tire.
Nothing complex but was scarry noise
Old 03-05-2016, 08:49 AM   #7
PardoR
PardoR's Avatar
The socket was forgeted by the shop when changed the struts and springs
Old 03-05-2016, 10:01 AM   #8
iHateVolvoPeople
Can't complain about free tools! Lol
