Old 02-28-2016, 06:58 PM   #1
PardoR
PardoR's Avatar
Default Blinking oil pressure light at idle sometimes driving
As I wrote on the subject, that light is blinking but is occassional. Mainly at idle.... Can it be the oil grade? Do I need a thicker oil?
The mechanic change the oil ( it was full of gasoline) but I dont know which one put on the engine....
The Odo is not working ... So i dont have the real miles on the Volvo.
Any ideas or advices?
PardoR is offline   Reply With Quote
Old 02-28-2016, 07:01 PM   #2
PDX240
Back from the DEAD
PDX240's Avatar
Loose wire at the sender
Or cracked insulation on the sender wire rubbing and grounding Out.
Is it the 1993 240?
My Blue 1986 245DL
Pdx240 feedback http://forums.turbobricks.com/showth...ghlight=Pdx240
PDX240 is offline   Reply With Quote
Old 02-28-2016, 07:23 PM   #3
gashog
gashog's Avatar
Gauges and idiot lights lie.
Verify with mechanical gauge.
Here comes the BOOST!
gashog is offline   Reply With Quote
Old 02-28-2016, 07:23 PM   #4
PardoR
PardoR's Avatar
Is it the 1993 240?
Yes! An unattended by former owners Volvo 240 1993 b230f N/A AT lh2.4
Old 02-28-2016, 07:25 PM   #5
PardoR
PardoR's Avatar
Where is located that sender on the engine?
Old 02-28-2016, 07:40 PM   #6
oldschoolvolvo
oldschoolvolvo's Avatar
To the right of the oil filter.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 02-28-2016, 07:49 PM   #7
impolvo
Is always busy
impolvo's Avatar
Get an oil pressure gauge
Idiot light comes on at 1/2 bar
Your idle might be too low to keep above 1/2 bar
Or maybe you need pickup tube seals they fail after a while and you look paw pressure
my feedback: http://forums.turbobricks.com/showthread.php?t=221335
Originally Posted by Stephen View Post
Thats why you get a mans car... A 740
Originally Posted by rancidponymilk View Post
You people keep crushing them, you're going to run out eventually.
impolvo is offline   Reply With Quote
Old 03-07-2016, 05:48 AM   #8
PardoR
PardoR's Avatar
Solved: the sender connector was melted! I rebuild it and rolling again ...
